Aftermarket electrical parts
Tell me about your thoughts/experience on aftermarket electrical parts.
I've been throwing a code for over 10 years and have replaced almost every part associated with it. I started with changing the accelerator pedal position sensor for a p1125 and p2125. It worked initially but within days the problem resurfaced so I thought it was due to another issue. (When you rework your own harness and buy an engine off craigslist there's always doubt/questions.) 10 years later and a lot of intermittent down time not using the truck, I think I'm back to this part. It is a Dorman part. Now I'm buying a different company's part to replace this...fingers crossed. With a lot of internet research I've heard some rumblings about using aftermarket parts. What say you? Lately I try to buy AC/Delco parts for my other truck/cars. Sometimes that's not an option. Any specific companies you like/dislike? Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
![]() ![]() Join Date: May 2015
Re: Aftermarket electrical parts
I try to stay acdelco whenever possible...other than that i look for made in USA
BMW & ASE Master Certified
How much are you saving.. aftermarket vs dealer...
And second what are you working with? Swap wise? harness?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#4 | |
2005 6.0L Lq9 with 4l60e * Reworked the stock harness and used all the stock components, including maf, map, ecm, tac module/wiring, pedal position sensor, throttle body and sensor, o2 sensors *Swapped out one at a time in this order: Dorman pedal position sensor, New tac module and it's wiring harness, APDTY throttle body sensor, Current Performance wiring harness with new Bosch O2 sensors, new Hitachi throttle body with sensor, and just now a new Standard Motor Products pedal sensor We'll see if I get the same error code with the new pedal position sensor. Maybe a new sensor from the dealer if it happens again. Otherwise, what's left? A NEW ECM, map sensors, maf sensor. Anyways, more of a question as to success/failure with aftermarket electrical parts.... I buy parts online for convenience. I'm happy to pay extra for quality. I just don't have the experience to know which company has quality parts...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() Last edited by OldCreek; 12-24-2019 at 06:39 PM. |
![]() Join Date: Sep 2005
i have used alot of dorman parts over the years i've had good luck and bad luck i try to stick with ac delo /oem brand when ever possible
![]() Join Date: Jun 2015
I had problems using Bosch O2 sensors. Replaced both with AC Delco and had no issues since.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
#7 | |
bosch o2 sensors are the worst i run a repair shop and will not use them it either oem brand or denso
subbed
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
