12-30-2019, 09:58 AM | #1 |
Rear end ratio?
Any thoughts on what a 61 c10 3/4 ton 4 speed with granny would have for a rear end gear ratio? Haven't bought the truck yet just trying to figure what trans I can replace with . Leaning toward a 700r.
12-30-2019, 10:14 AM | #2 |
Re: Rear end ratio?
Do you know the gear ratio?
Does it currently have a 4 speed or auto?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-30-2019, 10:20 AM | #3 |
Re: Rear end ratio?
I don't know the rear end ratio. That's what I was asking. The truck is a 3/4ton 4 spd. standard with granny low. I want to put auto in but not change the rear end. I want to be able to drive to town and not do 3000 rpm at 50 mph. Any thoughts on what the rear end ratio would be?
12-30-2019, 12:10 PM | #4 |
Moderator
Re: Rear end ratio?
Here is the chart on rear axle codes. The stamp is on the top of the drivers side axle:
12-30-2019, 12:32 PM | #5 |
Who Changed This?
Re: Rear end ratio?
If it's original, per the Rod's chart it's a 4.57 ratio. A 700R4 trans has a .7 ratio OD, so that would give you a 3.2 ratio in OD. That's a respectable drop in RPM! The 700 has a really steep first gear with a big drop in RPM from 1st to 2nd. A lot of people use a 200 for this reason. I think that I recall that a 200 needs a bit of beefing up if it's going to be used hard, though.
12-30-2019, 12:39 PM | #6 | |
Re: Rear end ratio?
12-30-2019, 12:33 PM | #7 |
Re: Rear end ratio?
Thank you Rocknrod looks like they were all 457 ratio. Probably not too good to cruise around in even with a 700r. So probably a rear end change, so it will be more user friendly. Just trying to figure out what I will all need before I go look at this truck.
12-30-2019, 01:39 PM | #8 |
Re: Rear end ratio?
You could put an nv4500 5 speed in it since it’s already a manual.
Or you can get a 14 bolt and Captn Fabs mounts and swap that out before your trans
12-30-2019, 08:50 PM | #9 | |
Re: Rear end ratio?
This is the route I took with my 64 C20. I swapped the original rear axle out with a 14 bolt with 4.10 gears and also put in a NV4500 from a 98 c3500. Hope to get it running and driving this summer. |
12-30-2019, 10:49 PM | #10 |
60-66 Nut
Re: Rear end ratio?
Your first post says '61 C10 3/4 ton. A C10 is a 1/2 ton with 6 lug wheels. A C20 is a 3/4 ton with 8 lug wheels. Additionally a '61 will not be a C series, it is an Apache 10 or an Apache 20. The C series did not start until 1962.
12-31-2019, 11:50 AM | #11 |
Re: Rear end ratio?
I didn't notice this Captain till you pointed it out. It is an Apache 20 eight lug wheels. I have been in half ton land too long. Thank you
12-31-2019, 11:54 AM | #12 |
Re: Rear end ratio?
When you say 14 bolt rear end? Not real up on this 3/4 ton stuff yet. Would that be a bolt in? What did they come in? Maybe I could do the rear end and leave the old trans for now. Thanks for the info
12-31-2019, 04:02 PM | #13 |
Re: Rear end ratio?
It won’t be bolt in, but Captn Fab has trailing arm mounts that you can use after you remove the leaf spring mounts.
12-31-2019, 06:37 PM | #14 |
Who Changed This?
Re: Rear end ratio?
I don't know about the interchangeability of the rear ends, but you could probably find a Dana 60 from a big block truck that has a 3.54 axle ratio. It would have leaf spring mounts, most of the time. I see that some have coils.
12-31-2019, 11:09 PM | #15 |
60-66 Nut
Re: Rear end ratio?
The 14 bolt was available in both the 10.5" full floating and the 9.5" semi floating configuration starting in 1973 in the C/K20's and 30's up into the 2000's somewhere when GM went to the AAM differential. So there are tons of them out there. Even if you do find a Dana 60 from a '67-'72 truck, the trailing arm mounts will still have to be moved to bolt up to the trailing arms in your '61.
12-31-2019, 12:29 PM | #16 |
Re: Rear end ratio?
Some 67-72 20 series trucks with V-8 & automatic had 4:11 gears in them & the 3rd member fits your housing. They can be hard to find though.
George |
