Old 12-30-2019, 07:40 PM   #1
SCOTI
SCOTI's Avatar
Hardware for Door Vent Window Frame?
The hardware of the Door Vent Window frames for my 64 are long gone/missing. The paint shop pulled the windows out & the hardware was lost there. I've tried several small machine screws but nothing seems to thread (and I'm trying not to force things until I know what I'm dealing with).
Does anyone know the size of the hardware that's used to secure the vent window frames to the door channel sheetmetal? These are the 3 fastening points along the front/top of the door frame I'm referring to (circled in yellow):
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-31-2019, 09:59 AM   #2
jeff_wilson70
jeff_wilson70's Avatar
Re: Hardware for Door Vent Window Frame?
When I rebuilt my vent window, replaced the originals with these stainless screws. They were a pretty close match. (They could be shorter, but these worked just fine.
jeff_wilson70 is offline   Reply With Quote
Old 12-31-2019, 10:49 AM   #3
SCOTI
SCOTI's Avatar
Ok.... Sheetmetal screws vs. machined threads. That might be why I was struggling to get any hardware started . There were only machine bolts/screws in the bucket so I assumed that's what was installed originally.
Not too many old trucks around to compare/verify with so I was going to check my dually today. It's an 89 Square-body but I thought I would see if the retaining hardware was similar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2021, 02:01 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Did we ever figure out what the correct size is? I'm considering tackling this in the next few days myself.
Old 01-05-2021, 03:36 PM   #5
SCOTI
SCOTI's Avatar
I just did a dry fit w/the frames & used SS sheet-metal screws like pictured above. They worked fine. If I recall correctly, one screw did need to be slightly longer vs the others (I believe 3/4 & 1" were the lengths).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2021, 03:39 PM   #6
The Rocknrod
Moderator
#6 or #8's?
Old 01-05-2021, 03:40 PM   #7
SCOTI
SCOTI's Avatar
#6 or #8's?
Arghh..... #8's I believe. I can double check that shortly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-06-2021, 10:07 PM   #8
PGSigns
PGSigns's Avatar
Pulled one of mine and it looks like 8X5/8". You can test the length with the vent window out. They need to go pretty much all the way in and not bottom out. The three tabs pull up flush to the inside of the door.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-07-2021, 10:23 AM   #9
SCOTI
SCOTI's Avatar
Jimmy
This seems correct. I had to use one longer as one hole just didn't seem to have adequate 'bite' @ the shorter length. Seems I used 3/4 & 1qty 1" (for the one hole). I used beveled SS screws as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-07-2021, 02:17 AM   #10
El_Guapo928
Mine are a mix of #8x 5/8” and #8x 3/4”. The 3/4 seem to have been added over the years, because they’re a different head design.
El_Guapo928 is offline   Reply With Quote
