01-01-2020, 05:16 PM | #1 |
Body panel differences between 67 and 68-72
I understand that the 67 bedsides have different mounting holes, what about the front fenders on a 67, besides not having side markers are the mounting holes the same? In other words can I run them on my 70 c10 with the original 70 hood? I'd like to run 67 fenders and bedsides.
01-01-2020, 08:48 PM | #2 |
Re: Body panel differences between 67 and 68-72
Need ‘67/8 hood or modify the later one
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
01-02-2020, 05:49 AM | #3 |
You would need a whole front clip to run 67 fenders, even the rad core support, even head light change, ( everything from the fire wall forward needs to be changed ) to run 67/68 on a 69-72
01-02-2020, 06:34 AM | #4 |
67/68 fenders and hood are longer than 69-72. 67/68 grille is sheet metal that integrates with the fenders and hood. 67/68 headlights sit wider than 69-72, so core support is different from 69-72.
'67 bedsides have different mounting holes?
01-02-2020, 01:51 PM | #5 |
Alright, I appreciate the replys guys.
01-03-2020, 05:14 AM | #6 |
1967 bed sides mounting holes are Exactly the same as 1968-72 bed side mounting holes. The only difference between 1967 & 1968-72 is there are No side marker light openings on the 1967 bed sides, otherwise it is exactly the same.
In regards to the front clip everyone's correct you will need to replace the entire front clip to use 67 front fenders and have them just bolt up without modifications required. Now you could modify the leading edge of the front fender on the 1967 fenders so that the 69-70 grille will fit over the front edge of the 67 fenders but it would be far easier just to cut out the opening for side marker lights on your 69-72 front fenders and then weld the opening shut to delete the side markers. Far easier than trying to modifying the leading edge of the 67 fender or grafting the leading edge of a 69-72 fender onto a 1967 fender to make it work in order to get the 69-70 grille to fit over it like it does on the 69-72 Chevy. Paul Jr @ GMCPauls |
01-03-2020, 05:16 AM | #7 |
Yeah, I'll just be filling in the side marker openings.
01-05-2020, 01:56 AM | #8 |
Some good information on this thread. One thing I didn't see mentioned is that GMC's used the same fenders from 68-72.
01-06-2020, 03:00 PM | #9 | |||
"I ain't nobody, dork."
Gary
01-06-2020, 03:48 PM | #10 |
01-06-2020, 10:52 AM | #11 |
landarts
Body mount rubber supports for 67-68 are different than the 69-72 for the front clip.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
01-07-2020, 03:23 PM | #12 |
'67 GMC used the same as Chevy '67s, except for fender emblem holes.
'68-'72 GMC used the same as Chevy '68s, except for fender emblem holes. '69-'72 Chevy fenders are Chevy-only. GMC followed the same shorter hood design change as Chevy in '69. The Chevy fenders changed to allow the grille surround to sit "into" the fenders. The 3pc GMC grille surround changed to sit "over" the fenders and fill back to the hood over the grille.
Tags |
bedsides, fenders |
