01-04-2020, 04:19 PM | #1 |
Roadtrip!
Lets talk heater cores...
So I am trying to put my non A/C jimmy back together and can't find a proper fitting heater core. The ones I have ordered locally have a big tank on the top and bottom and the oem brackets don't fit. What are you guys or gals using without having to modify? I am not looking for NOS, just something that fits correctly.
Thanks. I know you all like pics, so here is where I am at now...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-04-2020, 04:21 PM | #2 |
Re: Lets talk heater cores...
Sorry I can't help, but really I'm just here just for the pictures, not the articles
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
01-04-2020, 04:23 PM | #3 |
I had the same problem on my 1970 c10 heater core non ac
The brackets wouldn’t fit on aftermarket heater cores. Found a bronze copper on eBay that fit right. Posted via Mobile Device |
01-05-2020, 04:55 PM | #4 |
01-05-2020, 06:20 PM | #5 |
Roadtrip!
I appreciate all of the input. So it sounds like the aluminum tanked cores are not correct and I should find a copper one.
Leon, with the oversize aluminum tanks, they would be against the side of the box and right there if you were to put a screw in it.
01-06-2020, 12:40 AM | #6 | |
The Older Generation
I wondered about that. I know there isn't much room with the stock ones. LockDoc
01-04-2020, 04:41 PM | #7 | |
What! All of the STUFF you have and you don't have a good heater core?... j/k.... Luckily I have never had to buy one. If it will fit in the space, couldn't you make some brackets to fit it. Heat and flatten the ends on some #9 wire large enough to drill small holes in it for the screws. LockDoc
01-05-2020, 12:35 AM | #8 |
I am using an aluminum heater core from O’Rielly. It fit (kinda) but I don’t really like it. I got it about 3 years ago. If I recall correctly it was correct size length and width but a little thin. The wire brackets fit, but if I tightened the screws completely they would have penetrated the tanks on the core. I wound up using slightly shorter screws. I saved the old core because I think it could be fixed. (small leak where the upper pipe attaches to the tank.) If this aluminum one craps out I will try to fix the original.
1972 GMC K2500 Super Custom Matt |
01-05-2020, 07:27 PM | #9 | |
You may be on to something here. Given how hard it is becoming to find these correct-fitting ones, maybe someone on here will start producing and selling these modified brackets!
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
01-06-2020, 12:45 AM | #10 | |
I was just wondering if a guy could wrap a piece of firm foam around the top and bottom tank and make it a friction fit. The foam would have to be wider on the back side so it would press against the outside of the heater box. If the hoses were long enough and a person used the factory hose bracket on the inner panel there shouldn't be any movement. LockDoc
01-06-2020, 02:15 PM | #11 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-06-2020, 04:34 PM | #12 |
Roadtrip!
Well, I am going to roll the dice... I brought it into a reputable shop to see what it would cost to re-core it. He took it in back and pressure tested it with 20psi and said there is nothing wrong with it. Said it flows well also. Wish me luck...
01-05-2020, 12:50 AM | #13 |
I Bought one from auto zone the stock brackets did not work so I used stainless steel zip ties to hold it in place.
01-05-2020, 01:01 AM | #14 |
There are some OEM fit brass and copper I believe on Jegs, or Summit.
There are also some on the board someone has referenced at about 100 bucks a pop, brass and copper. Commen sense says to stay away from the aluminum ones they have never fit right from all the research here. |
01-05-2020, 09:33 AM | #15 |
Just did this for my non A/C '72.
This worked with no modifications. Advance Auto for $50 or $37.50 with 25% discount. Keystone Collision Hvar Heater Core Part # HTR010211 |
01-05-2020, 06:34 PM | #16 |
Roadtrip!
I went to the site and looked it up and that comes up as aluminum also. No good pics to show the size of the tanks. Any chance you had a pic of yours? The nearest store to me is 1.5 hours away...
01-05-2020, 07:10 PM | #17 |
I got my copper brass heater core from NPD. It fit like the original. Here is a link to the site and page.
https://www.npdlink.com/product/core.../194464/100664
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
01-06-2020, 11:06 AM | #18 | |
Advance Auto will ship it to your door for free with the order over $25. Just talked to a local radiator shop, they quoted between $100-$200 to recore the original brass/copper heater core(which I still have). Last edited by my04; 01-08-2020 at 01:45 PM. |
01-05-2020, 11:28 PM | #19 |
Did you look it up on RockAuto's site. Some of the parts have measurements.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
01-06-2020, 12:46 AM | #20 |
I second NPD. I got a brass one from there that fit like my original minus the leaks.
01-06-2020, 02:52 AM | #21 |
I have taken my original to a radiator shop in the past to repair/recore. I found that the A/C heater replacement core I got in the past was not correct. Will do the same when I get to that point on my renovation.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-06-2020, 08:20 AM | #22 |
I had read posts on this same subject before buying. I went with Brothers. When I pulled it out of the box I saw that it was the all aluminum type and thought ....Oh sh!#. But.....it slid right into place. Worked like a charm. No additional hardware needed.
01-06-2020, 11:16 PM | #23 |
A couple years ago I was able to find a NOS AC Delco. I bet if i had the old one tested I would have been told the same thing. But, I replaced it anyway.
01-06-2020, 11:34 PM | #24 | |
Roadtrip!
Making some progress...
01-07-2020, 03:10 PM | #25 | |
All of the ones I have had tested and used I have never had any problems with. You will be fine. Truck looks good! LockDoc
