Old 01-10-2020, 11:27 PM   #1
superdav
I need help with a steering gearbox rebuild
I need a rebuild kit for my steering gearbox and I've learned Amazon's car part finder is not trustworthy
so far I've bought
Edelmann 8522 which Amazon said was the right one for my 84 2wd and it wasn't, the first part I tried to put on was the wrong size, a piston seal
so i searched using the number on the casting 7802644 L and found the next one
Edelmann 7857 on Rock Auto and that kit is not right either. The bearings are way off.
The casting
superdav is offline   Reply With Quote
Old 01-12-2020, 04:39 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: I need help with a steering gearbox rebuild
EDELMANN 8523
SUNSONG 8401228
GATES 351300 {#2781} Stg. Gear Major Seal Kit
EDELMANN 8524 Power Steering Repair Kit; Includes Bearings Info One of our most popular parts
GATES 350440 {#2641} Includes Bearings; Stg. Gear Complete Rebuilding Kit Info One of our most popular parts
ACDELCO 36351300 {#19146616}
SUNSONG 8401229 Includes Bearings
(Only 1 Remaining)
ACDELCO 36350440 {#19146549} Professional; Includes Bearings
ACDELCO 07813631 Includes Bearings
800 GEAR VARIABLE
ACDELCO 05687182
Power Steering; SEAL KIT,W/VALVE RING,HYD STEERING GEAR
This is the list RockAuto for a 84 2WD.
you may want to talk to rock auto about your part your kit.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-18-2020, 04:27 PM   #3
superdav
Went to oreillys and ordered the Precision 28401229 which oreillys said was the same as the GATES 350440 but the bearings aren’t the same, the original has a raised ring around one end. I’m going to measure all the parts when I get home
Is this ok Or do I have a bastard gearbox?
Old 01-18-2020, 09:34 PM   #4
superdav
Anybody?
Old 01-19-2020, 02:04 PM   #5
kipps
Most folks just chunk out the cash and replace the box. I've done that in the past.
I'm glad to see someone pursuing a DIY rebuild. I hope you make it happen, and I further hope you document it to encourage others to do the same.
I've got a box that was left out in the weather with the lines off. I may pursue a teardown and rebuild of that at some point. If I do, I'd be thrilled to be able to follow someone else's experience, instead of attempting to blaze my own trail.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 01-19-2020, 06:06 PM   #6
superdav
There’s only one reason I’m rebuilding it because it the original part and it’s made by Saginaw just like my M1 carbine, I’d like to think they were made in the same factory. I want everything in this resto to be done with my hands if possible
Old 01-20-2020, 10:28 AM   #7
hatzie
Moderator
hatzie's Avatar
Some of the earlier Unit Repair manuals have detailed service info on the steering boxes.
The parts books will have the parts information. Sounds like the Chinese kits are not quite right. I've run into this with carburetors. Had to buy three kits to get the parts needed.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-20-2020, 02:20 PM   #8
superdav
It’s an 84, the first kit had the right “size” bearings the second didn’t, this one is just like the first the OD and ID are right but there isnt a ridge around the end. Everything else is identical, is this an acceptable replacement? I know it could be installed but I’m worried it could “wander” around
Old 01-21-2020, 11:08 AM   #9
v30crewcab
v30crewcab's Avatar
it won't go anywere. use it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-21-2020, 11:55 AM   #10
superdav
After watching multiple videos on YouTube of people replacing the same bearing with the same no ridge bearing I started on it last night. Only one of those videos had the same as OEM replacement but he didn’t say where he got it
