1970 C20 longbed stepside body swap questions.
I know this has been talked about a lot bit I have some questions that maybe some of you can help me with.
In the process of starting my swap. I have a 70 C20 longbed I plan on swapping the body onto the 02 Silverado 2500 duramax extended cab shortbed. I know most people I've seen shorten the frame due to wheelbase differences. Mine is about a 16.5" difference. I dont really have the capabilities to cut and weld the frame besides my harbor freight welder I can barely use. My main questions is, has anyone gotten around this by either lengthening the bed or making any other adjustments. Just want to know all my options before I start cutting into anything. Any other recommendations would be greatly appreciated on this build. Thanks |
Re: 1970 C20 longbed stepside body swap questions.
Here's a picture of the donor truck
![]() ![]() Join Date: May 2015
might be better asked in the 67-72 section..
but..if your gonna do this and are worried about your welding..id strip the body off the donor and take it to a certified welder and let them shorten the frame to match your wheelbase option of lengthening the bed wont be a easy chore either and probably would never look right with a bed that long but your also gonna need a lot more than just shortening the frame which I'm sure your already aware of
I appreciate the info. Didnt even realize I didnt post in the 67-72. Thanks
60-66 Nut
The later model frames are a LOT different than the '63-'87 frames.
