12-07-2003, 01:10 AM | #1 |
Stubborn oil filter
Does anyone have any suggestions on removing a VERY stubborn oil filter?
Thanks |
12-07-2003, 01:12 AM | #2 | |
Bloo
long screwdriver and hammer, beat it through and turn, it'll eventually stop ripping and actually come off (i had to do this on the 74)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
12-07-2003, 01:13 AM | #3 |
its all about the +6 inches
I'll asume you have tried the proper sized filter wrench already.
I've had to shove a large screwdriver through the body of more than one filter in the past, but sometimes that eill just cut the filter in two. When that happens, it is hammer and chissel time. Coating the seal on the filter with oil before instalation helps prevent this from happening. |
12-07-2003, 01:18 AM | #4 |
I may have to try that screwdriver but before I do I am going to try 2-3 strips of duct tape for some extra traction. When I put the filter on I coated the seal. This is the first oil filter to do this to me.
Thanks Guys once it stops raining for a bit I will give that a try if the tape doesnt work. |
12-07-2003, 01:24 AM | #5 |
I use silicone o-ring lube on EVERY oil filter I put on. I've done the screwdriver thing too, messy but usually works. Big channel locks, warm the motor up first, kitchen gripper thingys, hammer and chisel and tap on the upper flange in the off direction. tapping with a hammer from different directions to loosen up the flange, strap wrench, pipe wrench. If one of those don't work you are up a creek. If it doesn't come off and its a '67 I'll come take it off your hands for free since it will be junk with a wholed filter on it.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
12-07-2003, 02:21 AM | #6 |
Failure is NOT an option!
Another way to gain a little more leverage or more handle room is to use a belt.I've done it several times when I couldn't find my filter wrench.Pants sagged a little but got the filter off!!
House payment or truck parts?????.........why does life have to be so complicated? 1969 Chevy Shortbed Fleetside 1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto) 1990 Ni$$an hardbody( daily beater that has been really beaten!) 1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me) |
12-07-2003, 03:11 AM | #7 |
Sisyphus was my mentor!
I read about a guy in Chevy High Perf. who had the same problem. He destroyed the filter getting it off of the motor ( screwdrivers & the like) - turned out that one of the transmission bolts was too long & butted up against the filter. I guess he put the filter on before bolting it to the transmission. Is this a new motor or tranny? Just a suggestion....
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
12-07-2003, 03:16 AM | #8 |
Yep its a new motor used the old tranny in the swap though. I didnt see any bolts touching it on the tranny side either.
12-07-2003, 04:17 AM | #9 |
Stop your worries
I have found the answer! Needle nose Pliars and adjustable wrench will take out the ones that have been beeten to a pulp with only the ring left!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
12-07-2003, 05:15 AM | #10 |
http://www.lislecorp.com/images/clip...0/22000clp.tif
See if you can dig up one of these. They just grip tighter & tighter. It's a Lisle Model 22000 for standard diameter filters. I've never seen one fail, & it won't crush the filter. |
12-07-2003, 10:47 AM | #11 |
I have had good luck with a sheet of sand paper folded so both your hand and filter had grip and go at it. Last resort big fat screw driver standard 1/4 inch tears the filter 2 quick and you windup with pieces.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
12-07-2003, 01:27 PM | #12 |
Robert Olson Transport
i bought the filter wrench that looks like a big old channel lock plier and that has been a godsend with some of em.... the screwdriver trick only has ripped apart filters hammer and chisel works but sometimes ya wind uphitting something ya shouldnt and theres another kind fo filter removal tool that grabs the end of the oil filter gets into it and turns it
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-07-2003, 03:17 PM | #13 |
Cause the Chicks DIG IT!!
I don't have an oil filter wrench so what i do is improvise. i just found an old crappy belt for my jeans that i didn't wear anymore and wrapped it around the oil filter. That worked like a charm for me!!
12-07-2003, 03:34 PM | #14 |
do you have headers? do they come close to the filter? mine do and it is hard to get off.
70 longbed 496/th400/Ford 9" |
12-08-2003, 12:34 AM | #15 |
The battle is over. Skokie 1 oil filter 0. The oil filter wrench that looks like a pair of channels locks did the trick. I ounched a hole in it at the very end but all in all it is off and there was no damage to the engine. I put on a new filter hand tight
Thanks for all of the advice I tried it all but the belt That was next. |
