01-13-2020, 11:38 AM | #1 |
8-lug D44 rotor and hub
Looking to do new wheel bearings and spindle bearings on my 72 3/4t Burb with a D44. Already have bearings, but need new spindles and decided to do rotors while I'm at it. I'm having trouble finding the rotor/hub put together, or failing that, new hubs to put on rotors that are readily available/easy to find.
It's an 8-lug, open knuckle, big bearing, with the old Spicer blue knob hubs. I can find pics online of hub/rotor combos, but they never seem to be in stock. Any ideas of better search terms to find the hubs themselves?
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
01-13-2020, 12:54 PM | #2 |
Re: 8-lug D44 rotor and hub
whats wrong with the old hubs ?
just pop the studs out with a press or brass punch and BIG hammer swap rotors and install studs . its done all the time . if your hubs are junk for some reason then its the used market . and if so i happen to have a set of the hubs in good used shape .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-13-2020, 01:40 PM | #3 |
Haven't found anything wrong with the old hubs yet, just figured I'd replace it all while I'm doing the rest of it.
Edit: found these that look like what I have, but years are off. I need to check my axle tag to verify my info. I know the rear was changed to a '73MY 14-bolt in the 90s by a PO, but no record of changes to the front axle. https://www.partsgeek.com/kcscmsk-ch...-assembly.html
01-13-2020, 07:23 PM | #4 |
those are internal hub style like 1/2 ton and later 3/4 ton .
if your locking hubs or drive flanges bolt to the wheel hub then these will only work if you swap to the style spindle they use and bearings and new locking hubs or drive slugs . this part is NOT a normal change out part like todays newer stuff is .
01-13-2020, 08:08 PM | #5 | |
Thanks. I hadn't caught that in the picture in the link. I have the other style that bolts on, external hubs. I'll just plan on getting some new rotors, lug studs, and press the old out to split the hub amd old rotor.
01-14-2020, 10:46 AM | #6 |
you will want to have the rotor turned after you install them also. i've never had one run true after installing. after truing the brake pulsing went away.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
