01-24-2020, 11:29 PM | #1 |
Guest
Posts: n/a
Motor swap
I’m going to post up the progress of the engine swap in my 72 C20. It might not be exciting but it will be cool to look back on.
Started with a tired, stock 350. After getting it out, I sprayed the engine compartment with EZ OFF and power washed it. Last edited by letsgofast; 01-26-2020 at 01:27 PM. |
01-24-2020, 11:36 PM | #2 |
Guest
Posts: n/a
Re: Motor swap
Hit it with Satin Rustoleum
01-25-2020, 12:11 AM | #3 |
Guest
Posts: n/a
Re: Motor swap
Newness
01-25-2020, 12:16 AM | #4 |
Guest
Posts: n/a
Re: Motor swap
Blueprint Engines 365/405
01-25-2020, 12:40 AM | #5 |
Re: Motor swap
That is going to look good! Did you get a good deal on the engine? Too bad they dont sell big blocks like that.
01-25-2020, 01:31 AM | #6 |
Guest
Posts: n/a
Re: Motor swap
01-25-2020, 12:46 PM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Motor swap
Love those "Ochre" paint jobs! L-31 motor is a good choice, looks good!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-25-2020, 01:30 PM | #8 |
Re: Motor swap
Nice job on the prep work! That's the hardest part.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-25-2020, 01:45 PM | #9 |
Guest
Posts: n/a
Re: Motor swap
This one is actually “dark yellow”.
01-25-2020, 05:18 PM | #10 |
Re: Motor swap
Holley 6210 spread bore is a great carb for those motors.
01-25-2020, 09:29 PM | #11 |
Guest
Posts: n/a
Re: Motor swap
01-25-2020, 11:24 PM | #12 |
Guest
Posts: n/a
Re: Motor swap
More progress today. I fixed a leak at the shifter shaft and changed the transmission filter today. I also installed a 2500 stall converter.
01-26-2020, 02:56 AM | #13 |
Re: Motor swap
Sub'd for the update on driving!
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
01-26-2020, 01:30 PM | #14 |
Guest
Posts: n/a
Re: Motor swap
New trans cooler lines this morning and getting the motor out of the crate.
01-26-2020, 01:36 PM | #15 |
Re: Motor swap
I really enjoy this thread. Im excited about how it will drive. The blueprint 355 i put in my 71 is a great engine. Sounds great, and great fun to drive. Im sure you will be more than happy with it.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350 1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job 1953 Buick Special. GM 355. Just a good smooth engine. |
02-01-2020, 07:06 PM | #16 |
Re: Motor swap
Before you put coolant in it, your heater hose is on wrong.
Supposed to be intake to bottom of heater core, top of core back to water pump or rad. Yours needs to go back to rad as you need that port on the water pump for the coolant bypass from the intake. |
02-01-2020, 07:19 PM | #17 | |
Guest
Posts: n/a
Re: Motor swap
Here is the old motor. |
02-01-2020, 07:45 PM | #18 |
Re: Motor swap
That would work.
02-01-2020, 08:22 PM | #19 |
Re: Motor swap
Pretty sure you need to run the bypass (like a BBC) because of the Vortec heads.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-01-2020, 09:33 PM | #20 |
Active Member
Re: Motor swap
I'm glad others brought up the bypass as I'm having a hard time finding a solution I like for my vortec. Edelbrock and others sell a coolant bypass that fits below the thermostat housing, but my concern is the line is 1/4 instead of 3/8 - what have others done for their vortec bypass?
02-01-2020, 10:04 PM | #21 |
Guest
Posts: n/a
Re: Motor swap
If I were to move the lower heater core hose to the intake (brass plug next to the thermostat housing) and run the top heater core hose to the water pump, that should do the same thing, right?? Would it do the same thing if I took the top heater core to the radiator? I would think that coolant would be bypassing under the thermostat at that point. Anyone have thoughts on this?
02-02-2020, 11:00 AM | #22 | |
Re: Motor swap
You have a great looking build.
02-02-2020, 11:14 AM | #23 | |
Re: Motor swap
I dug this up for you. https://www.flowkoolerwaterpumps.com...perature-spike Time will tell. If you get temp swings you might need a bypass. |
02-12-2020, 11:00 PM | #24 | |
Re: Motor swap
02-02-2020, 01:08 AM | #25 | |
Guest
Posts: n/a
Re: Motor swap
