Old 02-02-2020, 05:42 PM   #1
BigBird05
Ignition key switch
The Alt light stays on with the key off unless I make sure I turn it fully off. What to replace and how to do it?
BigBird05 is offline   Reply With Quote
Old 02-02-2020, 06:27 PM   #2
kaycee
kaycee's Avatar
Re: Ignition key switch
What year ? I replaced mine in the 2000 K2500 a couple weeks ago ,you have to take the cover off the colum =clam shell a couple torx screws on the bottom half then it pops off remove the tilt lever it just snaps out and then push bottom half in anf the top half out should unhook from each other. Once these are off there is a small hole on top of ign. ,take a pik or straightened papre clip and insert in hole and turn ign key at same time should come right out replace with new. There are a couple of youtube videos to show you allso. not that hard to do
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-02-2020, 07:08 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
What is the alt light? I assume you mean the light that looks like a battery? With the key turned on or to accessory, and the engine off, the light should be on. Engine running, the light should be off. That’s normal operation.
95 S_Trucker is offline   Reply With Quote
