Old 02-02-2020, 07:55 PM   #1
twoskies
twoskies's Avatar
Help with Clutch noise
hi
ok, truck sat for a couple weeks, was waiting for a starter and was on call, got starter installed today, checked starter gear and flywheel clearance, was .021, hooked everything else back up, truck started perfectly, no starter noise, birds were singing, everything was good
let truck warm up, thought id go for a drive, pushed clutch pedal in and grinding noises, when truck is in gear(pedal all the way up) and in neutral, no noise
clutch, pressure plate and throw out bearing only have about 3000 miles on them
i do have about an inch or more of play before clutch engages from the top, after that , its noisy all the way to the floor
Thanks for any help
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 02-02-2020, 08:19 PM   #2
Mike C
Mike C's Avatar
Re: Help with Clutch noise
Still sounds like throwout bearing if it only makes noise when you are pushing in on the clutch.
BUT, I have an 86 K30 that only makes noise RIGHT before the clutch engages all the way but makes NO noise when disengaging, driving, idling, etc. And I haven't figure that out either.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-02-2020, 11:38 PM   #3
twoskies
twoskies's Avatar
ok just went out after the game, lol
sounds kinda tinny, i did remove and reinstall the flywheel cover when i changed the starter, might get lucky, ill check it out tomorrow
Old 02-03-2020, 03:22 PM   #4
twoskies
twoskies's Avatar
Ok was not the inspection plate. Flywheel is hitting starter gear when pushing clutch pedal in Anyone had this issue. Shim starter or. ? Thanks
Old 02-03-2020, 05:19 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
You may have a bad thrust gearing if the crankshaft moves that much. Gently pry the flywheel back and forth. If there is noticeable movement, a crankshaft job is in your near future. I guess it could be the starter Bendix drive spring. If the crank doesn't move, pop the starter motor off and check that out.
~Steven
Simi Valley, CA
Old 02-03-2020, 09:58 PM   #6
twoskies
twoskies's Avatar
had a little more time and a quick helper tonite, flywheel is not moving back and forth like i thought, did not start truck when i was under it, turned by hand under truck, still think its hitting starter drive gear, called Jegs, good people, tech told me to shim inside bolt closest to the block, will roll the starter out of the way, tried , did not make any difference, think im going to pull starter in the morning and get it headed back for a swap
the weird thing is no matter how i shim starter, it still engages and starts the truck with no noticeable grinding or after whine noise
