Bracket kit for Alternator, PS pump and AC compressor?
Is there a good bracket kit available for the 235 that offers everything needed to support alternator, power steering pump and AC compressor on the 235?
I presume another crank pulley will also be needed?
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
Re: Bracket kit for Alternator, PS pump and AC compressor?
Davis speed equipment is the go to supplier for the brackets for 235 and other six cylinders. https://davisspeedequipment.com/
They have several possible combinations/options to accomplish it depending on your preference or space.
I used Davis Speed Equipment for my AC brackets. They fit right and mounts the AC on the right side of the engine. The brackets I used for power steering and alternator were made by an individual who no longer makes them. I used him because his kit mounted the alternator above the power steering pump. You definitely don't want the PS pump above the alternator in case it leaks.
#4 | |
Nice setup there. I Like it that Davis gives you a few options to pick from. I've been looking at their pieces for my 292 but like the vintage air 292 compressor bracket better because it mounts the compressor lower.
Davis speed equipment sells on Ebay. The prices are the same but it may possibly simplify things on your end.
