02-06-2020, 03:24 AM | #1 |
235 Compression ratio upgrade?
According to the 1959 Chevrolet Owners manual I have, the 235 has a compression ratio of 8.25.
What would be the easiest way to upgrade that to around 9?
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
02-06-2020, 04:28 AM | #2 |
Re: 235 Compression ratio upgrade?
Shaving the head will bump the compression slightly...
Not sure what piston the 235 has , but if its dished , a flat top piston would bump it up...
02-06-2020, 05:12 AM | #3 |
Would be nice to know how much it can be shaved and how much that would up the CR?
02-06-2020, 09:37 AM | #4 |
You may want to try the stove bolt website. They are dedicated to the inline 6 motors. This site is really good but most of the engine mod guys are v8. There are a few into the 250 i6 motors but I haven't seen much as far as 235 mod people here. You may want to research the chevy blue flame Corvette motors as they were the hottest 235s.
02-06-2020, 01:56 PM | #5 |
This is a stovebolt thread from 2005 scroll down to the post by Tony.
Basically having the block decked so that the pistons are flush with the surface which has to be done on a bare block and taking about .060 off the surface of the head. https://www.stovebolt.com/ubbthreads...t&Number=51003 Valve to piston top clearance is critical when you start milling the head. Guys in the states look for the "848" (last numbers in the casting number) heads as they are said to perform. Those are 58/62 heads More stovebolt chatter on that here https://www.stovebolt.com/ubbthreads...s/11773/2.html I doubt the performance gain would be worth the added expense though. Great if you are hunting for a head because you need one but maybe not a better solution than using what you have now.
02-07-2020, 02:40 AM | #6 |
A lot needs to happen before I get this, IF I get to this. was just wondering. I suspect (hope / wish) that the truck will be just fine with the new diff.
02-07-2020, 11:31 PM | #7 |
The 235 doesn't flow enough air to really benefit from bumping the compression up. There''s a number of issues associated with milling the head. One being the intake valve is basically flush to the bottom of the head. The valve seat would need to be machined and recessed. You may also run into some piston and valve clearance issues by doing this. Has the block and head already been machined? Chances are on a 60+ year old engine, someone has been inside it. Exhaust ports on cylinder 2&3, 4&5 are siamesed, so you run the risk of excess heat by bumping up compression. If you're swapping heads, you need to make sure your block has the correct oil orifice for your rocker assembly also.
Anyhow, sorry about being a negative Nancy. Just sharing what I've learned over the years. Anyway, most guys just clean up the barnacles in the exhaust ports, install a 261 cam. Install split exhaust and a dual intake and drive away happy. |
02-08-2020, 12:07 AM | #8 |
Mechanical lifters help .I had one 235 rebuilt and they put hydraulic lifters in and big difference low power .
02-08-2020, 10:32 AM | #9 |
The 235 is expensive to work on and finding quality parts, even here in the states, is an issue. If you have one that runs, you're better off just leaving it alone. I've actually had 3 different 235's come through my garage. I got frustrated and decided a drivetrain swap is a better alternative. Looking at your other posts, it looks like you're not afraid to tear into things. You may come to a point of asking yourself, "why didn't I just install a small block?"
02-08-2020, 11:38 AM | #10 |
Sounds like it is indeed better to just leave it alone and drop a V8 in there if the 235 really proves inadequate.
02-08-2020, 12:02 PM | #11 |
I split the exhaust and added a dual intake and two carters, a definite improvement in performance. I loved the sound.
02-08-2020, 01:34 PM | #12 |
No pics, it did not happen :-)
02-08-2020, 08:05 PM | #13 |
My 235 started and ran pretty good when i got it, it had an “848” head on it. Head had no paint on it so assume it had been off and had a valve job? Who knows. Did the Fenton dual carb and Fenton dual exhaust. I used Holly 5210 progressive carbs from Vegas. Havnt had it on the road yet but it starts, runs and sounds good. Pics dont want to work.
02-09-2020, 10:04 PM | #14 |
02-10-2020, 07:01 AM | #15 |
Would the intake from a late 250 fit the 235?
I'm toying with the idea of grafting the double or tripple SU side draft setup from a 4.2L Jag six onto the 250 manifold and bolting this lot to the 235. That should solve most carb issues surely? (want to keep all 235 parts in storage.) I'm not interested in HP. I'm only interested in maximizing torque, idle up to 2500 RPM.
02-09-2020, 08:04 PM | #16 |
Back in 54 & 55 Chevrolet built the hottest factory 235 by installing what would later become the stock 261 cam, triple 1bbl carbs (one for each siamesed 2 cyl's), the "848" head and a dual exhaust. They advertised it at 150 HP. There are hotter aftermarket cams on the market now and one can add two Ford Escort 2bbl progressive carbs and probably match that HP output but you'll be hard pressed to squeeze out any more.
As mentioned above shaving the head too much upsets the valve geometry and increases the likelyhood of piston interference and there's no good way to port the head to gain any more flow. Knowledgeable engine builders often refer to the Stovebolt engine (216,235 & 261) as glorified tractor engines .... Changing the block to a 261, reusing the "848" head, going with dual intake and exhaust may get you over 150HP but not by much. If you want to run 65 - 70 change out the rear gears to 3:55, kits are readily available. Changing to a V8 ain't no piece of cake but many here will help you spend your money if you want to go that route, LOL. All that said I run a "hopped up" 0.060" over 235 in my 49 Chevy 3100 with stock drivetrain and I still smile when I take it out cruising back roads and highways but I leave the interstates to the more modern vehicles. It'll do 55 - 60 all day long and I've hit real close to 80 but only twice after I broke it in, I didn't want to blow it up after just building it LOL. Rebuild the engine to spec's, get a hotter cam, improve the carbueration and exhaust and change out you rear gears, you'll have a pretty good performer. Good luck. A couple pics of my 235 setup. |
