Old 02-08-2020, 08:30 PM   #1
mygmctruck1
Cargo light socket connector
Ok
Just received my cargo light but not sure where to find the adapter socket ? I found a socket pig tail 2 wire but not sure it will fit , as a regular 1157 type bulb Won’t
mygmctruck1 is offline   Reply With Quote
Old 02-08-2020, 08:35 PM   #2
mygmctruck1
Re: Cargo light socket connector
This is the pig tail connector I’m talking about .
Old 02-09-2020, 12:10 PM   #3
Andy4639
Old member
Andy4639's Avatar
This is what you need and you will also need the small switch.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-09-2020, 06:00 PM   #4
mygmctruck1
I have everything except the plug end for the light socket . That was my original question , where can I get one ?
Old 02-09-2020, 08:34 PM   #5
Andy4639
Old member
Andy4639's Avatar
Yes I know this. The picture I posted has the fitting. You will have to buy the wiring harness to get the part you want are find a used one.
Old 02-09-2020, 09:01 PM   #6
mygmctruck1
Smile Re: Cargo light socket connector
Ok , thanks
Old 02-09-2020, 09:25 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Cargo light socket connector
Ok , thanks
A rear tail light pigtail is the same connector by the way.
Old 02-09-2020, 10:03 PM   #8
mygmctruck1
Ok thanks
