Old 02-12-2020, 07:55 AM   #1
racerop
racerop's Avatar
Speaking of truck seats
On my 71 k-20 bench seat, i have thought
about getting a more comfortable seat from a
newer model but my only problem with the seat
is the back which makes my lower back sink
into the seat.
My question is there a way to repair what is
going on and bring back the seat to it’s or form?
racerop is offline   Reply With Quote
Old 02-12-2020, 09:25 AM   #2
maverickmk
maverickmk's Avatar
Re: Speaking of truck seats
Anything can be done. Just depends on how much you want to spend to get what you're looking for. I checked into having the factory bench redone and it was a lot more than I wanted to spend. My truck is a turd, so obviously I will be searching the junk yards for some Tahoe seats when I get it closer to road worthy.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 02-12-2020, 09:57 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Speaking of truck seats
The old seats can be redone but as sated they cost around $500.00 to do them right. Which isn't bad when you consider a Snowden seat starts @ $1200.00 and up!
I like the 90's model seats and the 99 Tahoe seats also. I had 90's 60/40 in my 71 for about 10 years til I swapped to the 99 Tahoe heated seats in my 71 but have the 90's bench seat in the ramp truck and have one for the 68.
Like stated it just depends on how much you want to spend.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-12-2020, 10:02 AM   #4
sick472
sick472's Avatar
If your handy with hog ring pliers and have a bit of patience...new foam (and maybe upholstery) can make an old seat much more comfortable. Our bench seats are the easiest seats to recover (read "least difficult" because pulling upholstery and attaching a few hundred rings can be taxing). You can even add thin layers of foam in the areas that you would like more support. I have done this with bucket seats to firm up the bottom and thigh area by cutting high quality carpet foam (not the stuff made out of recycled bits but the virgin made foam) and placing it where I want it, throwing the covers over the seat, having a sit-down to see if I like it, adjusting the layers and positions as necessary, and once it feels good...use a higher quality spay adhesive to attach it to the main foam and then recover permanently. I have added up to 2 layers of 1/2" padding in areas and still had plenty of upholstery pull to get it all hog ringed properly. What you are actually doing is firming up the foam in that area, so it makes it more stiff, but it also keeps it from sinking in so much hence the extra suporrt.
Tip...don't glue anything down until you know you can stretch the covers properly or you run the risk of tearing the cover or having to rip the foam back apart and it rips and tears a the glue is much stronger than the foam...don't ask how I know.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-12-2020, 10:11 AM   #5
cebra
I did mine for about $250, $150 new cover, $30 new springs/hardware, $10 hog rings, $60 layers of foam back/bottom. My foam was very thin but in tact, I just added layers (in hindsight too many but it is settling in. A good tip is to take scrap carpet and put the non-carpet side toward the bottom then put foam on top of this, it keeps the foam from going between the springs which is what generally happens after many years of use. This way you get all the foam padding back.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 02-12-2020, 12:15 PM   #6
maverickmk
maverickmk's Avatar
This is what I'm dealing with now, but really want to find a 60/40 like Andy has.
Old 02-12-2020, 12:38 PM   #7
cebra
Yeah, probably be cheaper for you to find a different seat, the full foam replacements are stupid expensive when they get that worn.
Old 04-17-2020, 12:11 PM   #8
EagleChief
EagleChief's Avatar
I've been sort of looking for a new seat for my truck. I want to stay with a bench seat, but I'm not sure what I really need when looking. These 40/60 seats you guys are pulling out of the 90's trucks... are those front seats? I see a lot of rear bench seats for sale, but not sure how those will work. If I remember right, rear seats were not the most comfortable things to sit in when I was growing up.
I see a lot of 2nd and 3rd row Tahoe seats for sale. I'm guessing the 2nd row would be better than the 3rd row?
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 04-17-2020, 01:19 PM   #9
71gmcC15
71gmcC15's Avatar
In the crew cab pickups the rear seat is the exact same as the frount bench seat. They changed in 95 but still the same rule. Here is my rear seat out of a 95 crew cab. Its has the added bonus of an arm rest.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-18-2020, 12:05 AM   #10
Richard2112
Richard2112's Avatar
Wow. That's a feature I would consider. A bench with a fold down arm rest. Nice. Now you got me thinking. Rear seat from a 95 crew cab. Interesting. Thank you for that.
Richard2112 is offline   Reply With Quote
Old 04-18-2020, 10:29 AM   #11
kaycee
kaycee's Avatar
Dont forget you wont have front to rear adjustment when using rear seat,You will have to fab brackets to mount the newer seats.Not to discourage you but a heads up on what you will encounter.Not that hard to fab up
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-18-2020, 01:38 PM   #12
71gmcC15
71gmcC15's Avatar
Mine has sliders on it From factory. No modifications made to them. The brackets are the same as the frount seat.in 88 -98 crew cabs any way.
Old 04-20-2020, 11:12 AM   #13
EagleChief
EagleChief's Avatar
Good to know! That helps me out a lot - on what to look for. Found a red seat from a 90's truck that has a fold down armrest. It's a red one, which I'd have to get recovered, but he only wants $150 for it. Think that's worth it?
Old 04-20-2020, 11:51 AM   #14
maverickmk
maverickmk's Avatar
I think it's worth it, but, I've been looking for that exact seat for several months now and haven't found anything.
Old 04-20-2020, 01:09 PM   #15
71gmcC15
71gmcC15's Avatar
It's hard to find one in good shape. So if it's in good shape I would jump on it. I got mine for free. I also sold one for $100 with a small hole. The thing is with 88-94 seats they can't be recovered. The fabric is glued to the foam. Not saying its impossible to do it but will cost a lot.
Old 05-06-2020, 10:51 AM   #16
EagleChief
EagleChief's Avatar
Well, I missed out on the seat. It sold before I could get to it. I was a little hesitant anyway, after you mentioned the recovering issues on those. For my budget, if I'm going to recover, I'll just reuse what I have. If I buy one, it needs to be in a condition & color that I can just install it and not have to worry about recovering it.
That being said, I did find a couple of nice (rear) seats out of a 2014. Has anyone used one of those before?
