Old 02-16-2020, 04:18 PM   #1
wesmigletz
wesmigletz's Avatar
Dorman 13503 Lower Control Arm U Bolts - just drill out with a 9/16" Bit?
While searching other threads, I saw Dorman 13503 recommended. These are a lot bigger than the ones they're replacing.
Did you just drill out the saddle/crossmember with a 9/16" bit?
Thank you
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 02-16-2020, 05:00 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Dorman 13503 Lower Control Arm U Bolts - just drill out with a 9/16" Bit?
I would suggest drilling it 14mm (0.5512)
And then reaming it with 9/16 (0.5625) reamer.
14mm drill
(link):https://www.homedepot.com/p/Drill-Am...-0MM/306365125
(9/16 reamer that could be used with 1/2 inch drill)
Link:https://www.homedepot.com/p/Drill-Am...9-16/307840594
Or 9/16 reamer that would require a chuck that would accept 9/16 shank.
link:https://www.homedepot.com/p/Drill-Am...3A%7B1%7D%3Anf
Yeah you could probably drill it with a 9/16 drill
Just be careful about breaking the edges off the twist drill.
Link:https://www.homedepot.com/p/DEWALT-9...20-G/202579650
84 Chevy K-20
Old 02-16-2020, 05:11 PM   #3
wesmigletz
wesmigletz's Avatar
Getter-Done. I appreciate your advice. I will get the 14 mm drill bit and reamer. I'll be doing both our 67 C10 and 70 2wd Blazer.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 02-16-2020, 08:50 PM   #4
68 P.O.S.
Yeah, when I replaced mine I drilled em out with the 9/16" bit. It's a good safety upgrade.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 02-16-2020, 11:05 PM   #5
wpavlis
Could you use a step bit?
wpavlis is offline   Reply With Quote
Old 02-22-2020, 09:45 PM   #6
wesmigletz
wesmigletz's Avatar
I installed them today. I just used a 9/16th drill bit, because I couldn't get a 14 mm bit locally and didn't want to wait for a mail order one. Went pretty quick, and the new u bolts look a lot beefier.
Thanks for the advice.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 02-22-2020, 10:17 PM   #7
Barnfind46
Barnfind46's Avatar
I did this upgrade after I took a wild ride with a camper in tow.u-bolt broke and almost lost the whole rig.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
