Old 02-17-2020, 10:06 AM   #1
Knothead
Knothead's Avatar
swb frames
Do the panels share the same frame with the swb trucks?
Knothead is offline   Reply With Quote
Old 02-17-2020, 11:04 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: swb frames
Panels (at least in 64) came in C14, K14 which are 1/2 ton - 115 wheel base. C36 which are 1 ton and C365 which are 3/4 ton - 133 inch wheel base.
Not to be confused with the suburban carryall panel door models C14 and K14, or the suburban carryall tailgate doors.
See? I have lucid moments.
I download the info from the GM Heritage center, you can also. Or get a 64 from here - https://app.box.com/s/r3ix7xdijprl91ho65fv9a8q5w34tbfi
Old 02-18-2020, 05:52 PM   #3
Knothead
Knothead's Avatar
Re: swb frames
Thanks , I have a 1965 115" wheel base 2WD. I'm going to put a K10 frame under it which leaves a frame available. Curious to see what it will fit?
Old 02-18-2020, 05:54 PM   #4
The Rocknrod
Moderator
Re: swb frames
Originally Posted by Knothead View Post
... Curious to see what it will fit?
What?
Old 02-19-2020, 08:39 AM   #5
Knothead
Knothead's Avatar
Re: swb frames
Guess I need to rephrase the question. The original 1965 panel frame , would a 1965 truck cab and bed bolt right on it ?
Old 02-19-2020, 09:16 PM   #6
Clyde65
Clyde65's Avatar
Re: swb frames
No, although they share the wheelbase(115”) the rear of the frame is totally different
Clyde65 is offline   Reply With Quote
Old 02-20-2020, 08:13 AM   #7
Knothead
Knothead's Avatar
Re: swb frames
Thanks for the response
Old 02-21-2020, 08:57 AM   #8
The Rocknrod
Moderator
Re: swb frames
Here is a build thread page that shows the chassis being worked on. I don't know what if anything is different I cant tell. - https://67-72chevytrucks.com/vboard/...=735403&page=2
Old 02-22-2020, 09:32 AM   #9
Knothead
Knothead's Avatar
Re: swb frames
Thanks for the link , great info . I like pictures !!!
