02-24-2020, 01:24 PM | #1 |
3 Point Belt Help
Hi
New to me 70 C10. Inside cab was painted before my tenure. Upper B Pillar hole barely visible I stuck one of those remote scopes up the inner B pillar and here are some pictures. I assume this is the upper seat belt mount? |
02-24-2020, 01:31 PM | #2 |
Re: 3 Point Belt Help
If memory serves, that is just a plastic plug on the inside of the cab screwed into the recessed mounting point.
The top bolt for the shoulder belt includes the special bolt that attaches to the mounting point. Someone else may chime in..... |
02-24-2020, 01:35 PM | #3 |
i have no plug. the top picture is about where the plug should be and I see a faint circle or hole that looks filled in.
02-24-2020, 01:39 PM | #4 |
At the body shop.
Drill into the center, see if it's been bondo'd or welded closed.
" That didnt make it any newer " " Dont antique the equipment " |
02-24-2020, 01:40 PM | #5 |
You got it....I had the plastic plug in mine before I installed 3 point belts.
It was an easy bolt in. Last edited by MySons68C20; 02-24-2020 at 01:40 PM. Reason: mis spelling |
02-24-2020, 02:06 PM | #6 |
SWB 4x4 Collector
That's it, looks to be full of bondo, shouldn't be a huge task to clean out the threads. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-24-2020, 02:51 PM | #7 | |
I think it 7/16 fine thread but will confirm before I do anything. ' am thinking the tap if I can get it started . i have some thread chaser set too. Thanks |
02-24-2020, 02:06 PM | #8 |
Old member
Yes mine had plastic cover in it. Somebody may have bondo it up though you never know. The nut is been in every truck I have ever seen though. All three of mine have them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-24-2020, 02:50 PM | #9 |
It's always impressed me that they had the thought to include the captive nuts for future use.
02-25-2020, 01:47 AM | #10 |
That's a good idea. Anything else I'd be missing?
02-25-2020, 04:33 AM | #11 |
you would want a cage nut, google it
02-25-2020, 06:04 PM | #12 |
My .02 is that I wouldn't be comfortable with just welding a patch in with a captive nut would not be strong enough.
Here's what I would do. Cut a piece of 1 1/2"? x 1/4" flat stock about 3" longer than the hole is in diameter. Weld a 7/16" nut to the back side of the flat stock and then drill back thru the nut into flat stock the hole correct drill size so you can tap the flat stock the same as the welded nut. Then center the flat stock in the existing (1 1/2") on either side of the big hole. Drill a couple of holes on either side so you can plug weld the flat stock in place. Now you have reinforced the mount just not the welding of the big hole. Then just make a patch to cover up the big hole. Just my .02. |
02-25-2020, 08:49 PM | #13 |
That was my original plan, hence the reason I was asking about any additional stock reinforcement besides just the cage nut welded onto the backside of the cab sheetmetal. It doesn't seem strong enough to hold the potentially violent motion of a seat belt pull.
02-26-2020, 05:27 PM | #14 |
Boy am I lucky no one screwed up my interior sheet metal. Dash is not cut, no crappy speakers in doors or kick panels, and no gun rack holes either...
71 C-20 07 Magnum RT AWD |
