Old 02-24-2020, 04:06 PM   #1
tdangle
tdangle's Avatar
Throttle cable
I'm changing out the rod throttle assembly on my 70 to a 71/72 cable type. I just picked up the entire assembly from a 72 at pick a part. Since the grommet is trashed as well as the plastic piece that locks the cable into the pedal assembly, I'm getting a new cable. They list 2 parts one for 2wd and one for 4wd. What is the difference?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-24-2020, 04:43 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Throttle cable
My guess is length - 4wd motors were set closer to the firewall so I suspect the cable for a K truck is shorter.
Old 02-24-2020, 09:22 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Throttle cable
Correct. You will want the 4x4 or shorter cable if you are in the rear mount holes.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-24-2020, 09:38 PM   #4
mygmctruck1
Re: Throttle cable
I could not find the proper length cable myself . Ended getting the longer one and modifying it myself .
mygmctruck1 is offline   Reply With Quote
