02-28-2020, 01:50 PM | #1 |
Anyone install DJM flip kit recently?
I'm looking at installing the DJM flip kit on my truck and was curious if anyone has done it in the past 2-3 years. My truck must have the HD rear spring option because I have a total of 8 leaves. If I go with the flip kit, I would take out the bottom 3 leaves and leave the rest. Also, what to do about the shocks? They'll be at a bad angle unless I relocate them and I'm not even sure the stock mounting locations will work with that much drop.
I have a 2-3" drop shackle on it now but it's conflicting with my bed floor and I'd like to get more drop.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
02-28-2020, 10:02 PM | #2 |
Re: Anyone install DJM flip kit recently?
don't remove leafs, I went with HD 5 leaf packs over 3 and love it, my post on my experiences back in the day: http://67-72chevytrucks.com/vboard/s...d.php?t=577529
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
02-28-2020, 10:06 PM | #3 |
relocating the shocks is included in the thread and I would go back with stock shackles and bushings over the drop ones unless the 8 leafs keep it up correctly. I have no notch and haul loads of mulch and sand no problemo
02-29-2020, 09:50 AM | #4 |
I have the HD springs on my ‘69, and they do not look like that. With that said, I removed the overload on mine because it was interfering with the Cal-Trac bars.
On yours, I would remove all the small leaves below the overload, not sure why they are installed? I would keep the overload unless like myself you are running some traction control device. The flip on my truck lowered it 7 1/4” in the rear. I drilled the factory upper shock mount second hole out and move the shock to be more vertical. With a 4.5” drop in front (2.5” spindles, 2” springs) I used stock length shocks all the way around.
03-02-2020, 10:45 AM | #5 |
Thanks for the info guys. I was able to get the stock shackles put back on this weekend but didn't get to put on a bedside and do some measuring. I'm torn between the flip kit for a 4.5/7 drop and a drop spring for a 4/2 drop.
03-02-2020, 10:58 AM | #6 |
Where is your fuel fill ? ....if its in the bed side could be an issue.
03-02-2020, 12:12 PM | #7 | |
I'm looking at 4" drop leaves. I think 7" will be too much.
