03-07-2020, 08:04 PM | #1 |
Automotive clear on bed wood?
Anyone use an automotive clear on their bedwood? Any pictures?
03-07-2020, 08:46 PM | #2 |
Moderator
Re: Automotive clear on bed wood?
No. I wouldn't use a product not made for wood..
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 03-07-2020 at 09:04 PM. |
03-07-2020, 09:28 PM | #3 |
Who Changed This?
You could, but it might not stand up to much abuse. Then again, some of the new finishes are pretty dog-gone tough. If you're only hauling A$$, it should be OK. Have a chat with your paint retailer!
03-08-2020, 08:14 PM | #4 |
people have used SPI clear on wood go to the SPI forum and do a search for more info
03-09-2020, 09:53 AM | #5 |
It's Better With Nitro
Use a spar marine urethane. Wood expands and contracts a lot more than sheetmetal.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
03-09-2020, 11:41 AM | #6 |
for a near clear finish, I used these marine products..
2 coats Penetrating Epoxy 6 coats Gleam 2.0 Spar Varnish as Vin stated, I would avoid metal finish products on wood.. especially since such great wood products available today.. I even avoid metal finish products on metal good luck!
I started out with nothing - and I still have most of it |
03-10-2020, 09:04 AM | #7 |
03-11-2020, 02:56 PM | #8 |
Hey thanks for the great info!
03-11-2020, 07:43 PM | #9 |
Check out the tests on mar-k.com, under tips and tricks.
Chris |
03-13-2020, 01:41 AM | #10 | |
something to consider though is the quality of the products they used.. my childhood friend's dad is a master cabinet maker now in his 70's.. he told me to disregard anything sold at home depot for DIY'ers, they're woefully inferior.. by comparison, the total boat deep penetrating epoxy is $157/gal, I made it through my longhorn deck with just under a half gal.. the total boat gleam gloss spar varnish is $95/gal.. I bought a gallon as it has other uses but only used about a third of it for 6 coats on the longhorn.. my friend an his son painted their longhorn deck based on this study and it started failing in 2-3 years.. not sure what products were used but it wasn't the cheap stuff, their results otherwise are stunning.. professional products used properly to protect wood in marine applications may not last forever but certainly should fair better than what was demonstrated by that testing.. I seriously doubt the hard shell epoxy coating on the boards I treated ends, edges and all, will look anything like those tested.. and maintenance coats of spar varnish should preserve the uv protection for many years.. paint touchup would seem to me more labor intensive than varnish maintenance recoating.. for decent paint work, the strips would probably need to be lifted, varnish probably not.. so it really boils down to what your preferred appearance is, intended application, and storage options.. paint was factory oe and most lasted many years.. but likewise, many vintage boats out there are well preserved in marine coatings.. I preferred the wood grain appearance for my project so I went for it.. the ochre longhorn parks in a barn so not overly concerned.. the red longhorn parks outside here so we'll see.. I actually wanted to try painting my red longhorn deck to match but was out voted by everyone, NO one agreed with me on paint so I'm going with epoxy and varnish again dad's 65 will be next so should have this all figured out by then good luck!
