03-10-2020, 02:02 PM | #1 |
Interior firewall floor redo questions
For the firewall, I wondered if I need to install both sound deadener and a firewall insulation pad or is it just one or the other? This is the pad I thought to get
https://www.brotherstrucks.com/1960-...tinfo/FWIP066/ Also when installing the carpet over the sound deadener in the floor of the cab, do you need some jute in between? Or isnt that normally on the carpet? |
03-10-2020, 02:52 PM | #2 |
It's Better With Nitro
Re: Interior firewall floor redo questions
It's kind of a personal preference thing. I did a butyl-based sound damplifier on the floor and all the way up the firewall. I also installed the interior firewall pad with the jute backing. Then I installed the carpet with the jute backing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
03-10-2020, 03:51 PM | #3 |
Yeah, I have seen a range of methods. I also watched a video brothers had and it looks like they dont sound deaden completely only in strategic spots and then put some kind of foil like covered jute.
https://www.youtube.com/watch?time_c...ature=emb_logo I had thought to do what you mentioned Vin63, cover the floor and firewall with the sound deadener, then do jute or foil like jute and then carpet. I didnt want to double up though on the jute if it already came attached to the carpet and make it too thick if thats a no no. Looks like they did though in the video. |
03-10-2020, 05:26 PM | #4 |
I run a 3-inch exhaust that is routed to the outside of the frame, so I wanted to quiet things down as much as possible.
