Old 03-13-2020, 09:06 PM   #1
68350
68350's Avatar
1968 Power Steering brackets
Can someone post pics of their brackets on an ORIGINAL power steering set up on a small block 1968 pickup? Im guessing the bracket with the adjustment slot attached to the bolt that holds the motor mount to the block? Looks like one hole in main pump bracket that attaches to lowest hole on front of block. Then I have another small bracket as well. Could be for PS or alt. Should have taken photos a year ago. And it appears 69-72 uses a different bracket set up
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 03-13-2020, 10:26 PM   #2
kwmech
Re: 1968 Power Steering brackets
All I have to take a picture of would be what I took off of a 72. I have never seen anything different than that. Only difference I can think of may be when these first came out in 67 and offered power assisted steering, but I haven't seen one of those in probably 20 years
Old 03-13-2020, 10:35 PM   #3
68350
68350's Avatar
I have lots of 69-72 set ups and of course theyre not even close it doesnt appear. The alternator looks to use the bolt coming out of the front of the exhaust manifold instead of having a lower bracket?
Old 03-13-2020, 11:19 PM   #4
randy500
68 ps mounts the same as later years, the back bracket is cast iron though.
The alternator does mount with a front bracket and bolt through the alternator and into the exhaust manifold.
randy500 is offline   Reply With Quote
Old 03-13-2020, 11:32 PM   #5
randy500
68 brackets on left, 2 piece, brackets on right are not related.
Old 03-14-2020, 10:05 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1968 Power Steering brackets
Not a 100% sure if they are correct are not. I know the one aluminum isn't because I just installed it yesterday because the other one was not long enough to adjust it tight.
This is on my 67 Ramp truck with passenger side alternator.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-14-2020, 10:08 AM   #7
Andy4639
Old member
Andy4639's Avatar
Here is the setup on the 68 I just sold. It has the drivers side alternator.
Old 03-14-2020, 11:48 AM   #8
uncle
Here’s some from my 68 GMC. Not very good but about all I can get with it in the truck.
uncle is offline   Reply With Quote
Old 03-14-2020, 11:49 AM   #9
uncle
2222
Old 03-14-2020, 06:48 PM   #10
68350
68350's Avatar
Thanks a bunch everyone! I think i can piece my puzzle together with all of the photos
