![]() Join Date: Aug 2018
1970 292 4wd engine part out
Parting out 1970 292 4wd engine.
Valve cover: 40$ Push rod cover plates: 30$ Two piece thermostat housing(top aluminum cast piece broken): 30$ Alternator and brackets: 40$ Fan assembly and water pump pully: 40$ Fuel line from pump to carb: 15$ 4speed Z bar engine bracket: 20$ See anything else just ask... will sell whole engine for 250 local pickup only. Engine is not froze up turns over freely. 4wd engine crossmember 292 only: 200$ Motor mounts and stands LH and RH: 60$ Also have a 6cyl offset aircleaner setup for sale. Not perfect but 90% complete for 100$ All Prices are plus shipping. PayPal or MO. Thanks Posted via Mobile Device Last edited by ShortbedClayton; 03-17-2020 at 11:27 AM. |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 1970 292 4wd engine part out
How much for the tow hooks?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: May 2011
Carpe manana
I figured you’d want those - nice find and good luck with the sales.
I’ll take the fuel line
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Yeah, I after thinking about that I’d be better off bending one up. Thanks anyways.
No problem.
Posted via Mobile Device |
How about the 3 grove harmonic balancer?
will send a PM
#15 |
Contur is looming for an oil bath air cleaner
#16 |
Do you have pics. of the air cleaner set up?
Thanks Russ |
#17 |
I do. Little piece on snout is broken off but I can tack weld back on if you want me too..
#18 |
#19 |
#20 |
#21 |
I guess nobody needs 6 cylinder parts... TTT feel free to make reasonable offers on the motor pieces... firm on the crossmember and mounts
#22 |
Bump
