Old 03-18-2020, 10:30 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
Horn relay clicks, no horn
Just like the subject. I hear the click but no sound. Is this as easy as replacing the horns?
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 03-18-2020, 10:51 PM   #2
Metaldoc
Metaldoc's Avatar
Re: Horn relay clicks, no horn
Go online and look up how to fix horns. Fixed mine and it's been working for yrs
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 03-18-2020, 10:51 PM   #3
ray_mcavoy
Simply replacing the horn may or may not fix the problem.
You might still be dealing with a horn relay that has bad contacts and isn't sending power to the horn even though the contacts are clicking closed. Or there might be a bad connection in the wire connecting the relay to the horn. Or a bad ground at the horn.
Some additional testing with a multimeter, test light, or jumper wire should help locate the problem.
ray_mcavoy is offline   Reply With Quote
Old 03-18-2020, 11:03 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
This. Your horn button sends ground through a wire in the steering column to operate the horn relay. You can hear the relay operate (click) so that part should be good.
When the horn relay operates, it sends 12v to the horn(s) on the green wire. Test that wire for voltage. If voltage is present on the connector to the horn but it still doesn't work, you may have a defective horn or a bad ground (through the horn's mounting bolt).
If there's no voltage at the horn's connector, it could be a wiring problem or a bad horn relay. Chase it down with your test light or VOM.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-18-2020, 11:26 PM   #5
phlegm
phlegm's Avatar
Perfect, this is simple enough even I can do it
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 03-19-2020, 12:16 AM   #6
toolboxchev
Are not the old horns adjustable to an extent...I seem to remember seeing what looks like a machine screw? Maybe to adjust pitch?
toolboxchev is offline   Reply With Quote
Old 03-19-2020, 12:18 AM   #7
Killer Bee
Killer Bee's Avatar
just went through this with my red longhorn.. turned out both horns b/o, expensive critters!
this was my horn tester in my dad's 65 when I brought it out here
Killer Bee is online now   Reply With Quote
Old 03-19-2020, 06:43 AM   #8
racerop
racerop's Avatar
You have a bad ground
racerop is offline   Reply With Quote
Old 03-19-2020, 04:47 PM   #9
notsolo
notsolo's Avatar
Thanks for posting a simple solution, that helped get mine sorted out....2 bad horns. Now It works.
notsolo is offline   Reply With Quote
Old 03-20-2020, 06:07 PM   #10
phlegm
phlegm's Avatar
So I am getting 12 v at the horn, cleaned the contacts and the bolt and mounting plate to make sure I have a good ground. I am thinking that one of them was already gone and I only now notice it because the working one isn't any longer.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 03-20-2020, 11:44 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Last ditch effort -- sometimes you can revive a dead horn by spraying WD-40 into it. More is better. May have to leave it a day or 2 before it can work its magic.
Or it just might be time for new horns. If I'm ever faced with that, I just might consider the 4-horn Cadillac setup.
- Mike -
RIP El Jay
Old 03-21-2020, 03:30 AM   #12
phlegm
phlegm's Avatar
I want an oooooggggaaH horn! I'll try oil, worked on the locks, so worth a shot.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 03-21-2020, 03:45 AM   #13
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
They have an adjustment screw and lock nut on the back that sometimes needs an adjustment. I did that to mine a few years ago and it's worked every since...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-21-2020, 04:16 AM   #14
'68OrangeSunshine
'68OrangeSunshine's Avatar
You can rebuild the horn[s] by drilling out the rivets, cleaning, de-corroding the insides -- if necessary -- and securing back together with screws and nuts in the ex-rivet holes. Takes a while, but they're not Chinese and they'll sound American when they work, and fit w/o modification.
Old 03-21-2020, 09:59 AM   #15
68 P.O.S.
Hahaha, very nice Andy
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-21-2020, 11:24 AM   #16
hamjet
hamjet's Avatar
Pretty cool Andy, I like it!
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-21-2020, 08:50 PM   #17
Andy4639
Old member
Andy4639's Avatar
Talking Re: Horn relay clicks, no horn
On the Hot Rod Power tour it was great when people where sitting on the side of the road and I played it for them! I got a bunch of thumbs up from them!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-22-2020, 10:50 AM   #18
phlegm
phlegm's Avatar
I ended up putting in the cheepos from HB, they don't sound too bad and at 9.99 for both I can replace them a fee times. Only had to run a short wire to the chassis for the ground.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 03-22-2020, 04:35 PM   #19
'68OrangeSunshine
I have a pair of Harbor Freight ''Freeway Blasters" [?] by Fiamma in my '71 GMC Jimmy. Hi -Lo, agressive tones, hi dB. To my surprise, they were made in USA [then]. Maybe cost ~$17 then. Still work great. Saved the Delco Remy horns for later resurection.
On my '68 C/10 Stepside, I rebuilt the OEM horn [Single unit, key of 'C'] and added a higher pitched one from a '70s Mercedes. When they sound off, it's like jazz, Man... Like Monk on a rant. Unfortunately, I can't find the short in the steering column. The Black wire is not pinched. Horn relay's always on, or clicking on turns. So it's disconnected until I can R&R the steering column and replace the upper and lower bearing races, and hopefully then the horn contacts will play as intended. If that doesn't work, I have a black cheapie horn button from AutoZone, but there's really no space on the side of the column with a 3'' hose clamp holding the Tach in place.
Until it's fixed, I'm stuck using ''Italian'' hand gestures, or glaring silence at offending drivers.
