Old 03-21-2020, 12:43 PM   #1
HeavyHauler
What reared end diff gear lube for a stock 1968 Chevy C10 12 bolt rear?
What weight of differential lube do you guys use for your differentials. I need some for my 1968 Chevy C10 fleetside shortbed with a 12 bolt Chevy.
HeavyHauler is offline   Reply With Quote
Old 03-21-2020, 01:25 PM   #2
truckster
truckster's Avatar
Re: What reared end diff gear lube for a stock 1968 Chevy C10 12 bolt rear?
I use 75W90. If it has posi, I use Royal Purple synthetic - it doesn't require any friction modifiers.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-21-2020, 01:38 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I use Mobil 1 75W90 in both diffs (F&R) and in the t-case.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 03-21-2020, 03:04 PM   #4
HeavyHauler
Anybody know how many quarts a C10 12bolt truck differential takes?
Old 03-21-2020, 03:29 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Offhand, about 2 or 3. [Diff capacity is not stated in my Haynes manual.] The usual procedure is to pump the gear oil into the Fill hole, until it dribbles back out.
GL-4 for normal differentials, GL-5 for limited-slip, ''Positraction'' types.
In Tucson, where it can hit 114*F on a ''nice day'' in the Summer, I use 85-130 wt.
'68OrangeSunshine is online now   Reply With Quote
Old 03-21-2020, 03:23 PM   #6
truckster
truckster's Avatar
Roughly 2 quarts.
