6bt motor mounts for 69 GMC 5500
Not having much luck finding a source for these mounts, either to buy or fabricate. End result will be a 2001 24valve with Allison in my 5500 with a Dana60 / 14FF.
Thanks in advance!
1994 C1500 rclb 1988 C1500 rclb 1969 ES5500 B E A S T 1983 C10 'farm truck' 1976 K20 Suburban 1984 K10 Suburban 1981 Jeep CJ5/350 Vortec 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
Re: 6bt motor mounts for 69 GMC 5500
You could look into getting some mid-90's Ford F-600 mounts and adapting them to your frame. I had some before when I got the Cummins for a potential swap for my 69 C-50 but wound up going Duramax route instead.
You can also look up RTech Fabrication out Idaho either on FB or IG and look at some of the phots they have for the Duke and other builds. They have Cummins & NV4500 in their builds and will at least get you closer in way of fabricating something on your own. Good luck and let us know if you come up with anything that is close to bolt on!
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint) 1969 GMC C10 Pickup SWB Stepside (heart transplant) 1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts) 1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts) |
