03-28-2020, 09:39 AM | #1 |
Is There an Easy Way to Know Which Size Clutch I Have?
I have now come to the part where I can actually drive my truck and on it's maiden voyage I realized why it most likely was parked. The clutch is gone. So, with that said, is there a way to tell if it's an 11" or 10" before I pull the trans? All the places I search have both listed and I would like to have all the parts on hand when I start so I can finish it in one effort. Does it even matter which one I get? It's a '69 250 cid 3 on the tree. Those are the specs I search under and get both clutch sizes.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
03-28-2020, 10:04 AM | #2 |
Re: Is There an Easy Way to Know Which Size Clutch I Have?
FWIW......I've got a 69 250 3 on the tree and it has an 11 inch. I just happen to have it laying here.
03-28-2020, 12:55 PM | #3 |
got an 11 in my 72 with a 4 on the floor, granny gear, i would make sure you buy a good flexplate, i went cheap and it flexes, ill probably end up having to drop the transmission at some point, not something you want to do twice
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
03-28-2020, 01:07 PM | #4 |
Flex plate? Those are for automatic trannys. There are 3 parts to a clutch setup: flywheel that is attached to the crankshaft, the actual clutch plate that has splines and is attached to the trans input shaft (slides over it) and then the pressure plate which is what the clutch pedal is attached to. What do you mean by "flexes?" Could it be a stiff pressure plate and you're getting some deflection in the clutch pedal mechanism/arm? There shouldn't be any flex in a clutch setup, unless you maybe need a different descriptor for your issue - ?
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side Last edited by maverickmk; 03-28-2020 at 01:12 PM. |
03-28-2020, 07:52 PM | #5 |
That looks like a 10 1/2" to me (often listed as a 10 3/8")
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
03-28-2020, 07:58 PM | #6 |
Who Changed This?
If you can get at the pressure plate, you can measure the distance between the bolts. Different diameter parts would have different separation distances. The bigger clutch would, of course, have the bolts farther apart. Then you can go to the parts store and have them pull both pressure plates to compare. It's been a dog's age (or two) since I've put in a clutch, but if there is just a thin sheet metal cover on the front of the flywheel, I think the bolt holes are tapped through. You could still measure it that way. HTH
03-28-2020, 09:11 PM | #7 | |
03-28-2020, 07:58 PM | #8 |
yes
03-28-2020, 06:46 PM | #9 | |
03-28-2020, 07:25 PM | #10 | |
Nope, no HD on it at all. Thanks for the info, I appreciate it.
03-29-2020, 02:41 PM | #11 |
I got the clutch pulled out today and now I am stumped as to the size. Do I order an 11" or a 10"??? It measures almost exactly 10 1/2".
And isn't that clutch a beauty
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side Last edited by maverickmk; 03-29-2020 at 03:15 PM. |
03-29-2020, 02:58 PM | #12 |
Who Changed This?
Missing pieces usually means someone was side-stepping the clutch.
03-29-2020, 03:31 PM | #13 |
It's exactly what the tape measure says --- 10 1/2 inches.. Don't "order" anything.. In these hard times, support your local economy.. Take your wore out pressure plate, clutch disk, and throw out bearing to the local auto parts store and tell them you want a 10 1/2 inch clutch kit.. They'll want the old stuff for a core.. If your flywheel looks anything like the pressure plate, it'll need refacing also...
03-29-2020, 10:48 PM | #14 | |
Who Changed This?
03-30-2020, 08:42 AM | #15 | |
03-30-2020, 09:04 AM | #16 |
Summit about $200.00 with free shipping
Zoom MU Series Clutches MU5473-1B Pioneer Flywheels FW-100 double check part #s and buy new ARP flywheel and pressure plate bolts and you'll only have to do it once . don't resurface heat checked flywheels .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-30-2020, 09:27 AM | #17 |
Rock Auto has clutches for $75.00 with $10.00 shipping. I have a 5% coupon code which just about covers shipping. Locally, the cheapest I can find is a 10" for $120.00.
03-30-2020, 03:20 PM | #18 | |
Son, I've had wrenches in my hands for over 60 years.. How many clutches have I replaced?? Counting front wheel drive and foreign built, oh, probably somewhere in the thousands.. So can the smart ass attitude in my presence.. |
03-30-2020, 03:47 PM | #19 | |
04-03-2020, 10:44 AM | #20 |
If anyone cares, if you pull out a clutch from a 250 cid I6 and it physically measures 10.5" you need to order a 10" clutch, not an 11".
04-03-2020, 12:44 PM | #21 |
Interesting!
If the disc measures 10.5 then what does the pressure plate measure? |
04-03-2020, 01:02 PM | #22 |
If you look at the picture I posted it measures 10.5" as well.
