03-31-2020, 05:19 PM | #1 |
c30 factory rear sway bar end links
anyone got a good part number for 1979 c 30 dually camper special 4 door sway bar end links or a number for a kits that will work?
04-01-2020, 09:31 AM | #2 | |
Re: c30 factory rear sway bar end links
Are you missing something?
04-01-2020, 10:45 AM | #3 |
this truck was a basket case when i got it and the guy that took it apart didn't keep any of the old parts so i have the spring plate bar mounts the bushing brackets and the bar it self. i cant find a end link kit to order and have no old parts to go by to know how long the spacers and bolts in the end link need to be.
04-01-2020, 01:18 PM | #4 | |
Beyond that, it's just the bolt that goes through the sleeve & the bushings/washers @ each end. I always upgrade to Energy Suspension pieces there as well as up-size the bolt (they're usually 5/16 so I step up to 3/8). Worst case, you can always go shorter or longer on the sleeve. I usually trim them shorter to allow the bar to do it's job sooner but my stuff is always getting lowered.
04-01-2020, 08:26 PM | #5 |
Here you go
04-01-2020, 08:51 PM | #6 |
Energy Suspension Sway Bar End Link Sets 9.8149R is universal
