12-09-2003, 05:21 PM | #1 |
Keep it gangsta!
It won't pass emissions!
Here's the deal, when I take the truck through state inspection, It does great, except for the idle test. Carbon monoxide and hydrocarbons at idle are way over the limit. It seems like theres a little unburnt fuel passing through the system. I have an eldelbrock carb, slightly cammed 350.
What do I need to do to get this thing to pass?
1984 K5 Blazer 305-NP208-700R4 Ex Police Unit It's old school, but moves along nicely... '78 C-20 - SOLD |
12-09-2003, 05:28 PM | #2 |
driving is in my blood
LOL, yeah I get that every time here in phoenix. Turns out somehow the answer is to DROP the base timing down and run ported vaccum for the advance
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-09-2003, 05:29 PM | #3 |
It may be missing a little bit, mine is missing some but I don't think its related to my carb or ignition system. I think my cam is bad, its got some knocking in the engine too, so I think thats my problem. Maybe your idle mixture is wrong or you have some bad ignition parts.
12-09-2003, 05:43 PM | #4 |
What Hump?
I feel your pain, I went through the same problem last April, after 4 trips and $350 later even trying to get a waiver it finally passed after the carb as rejetted by a mechanic.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
12-09-2003, 05:45 PM | #5 |
also adjust the idle mixture screws in. youll have to idle it back up after wards. turn idle mixture screews in all the way till you feel it start to resist, than back out about 3/4 turn & try that.
75 GMC C-15 short/step factory 454, lowered |
12-10-2003, 01:46 AM | #6 |
Oh Look Out!
I said "forget it" and took it to a place that works on drag cars, they got it to pass. It went from 2600 hc to 13 hc.
Dan's Webshots "I have a lot of growing up to do... I realized that the other day inside my fort" - Zack Galifianakis. |
12-10-2003, 02:16 PM | #7 |
Check out GMTrucks.org
Whenever I don't pass on the idle, I lean out the idle mixture screws and get a new air filter. That usually does the trick for me.
12-10-2003, 02:49 PM | #8 |
Robert Olson Transport
id also throw a new set of plugs that always helped me
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-10-2003, 04:35 PM | #9 |
Keep it gangsta!
Leaned it out a little, messed with the timing...boom! Passed!
Barely... Thanks for the comments!
12-10-2003, 11:52 PM | #10 |
i just got my 82 to pass... it was way rich the first time and the shops around here wanted $50+ just to tell me what was wrong so instead i bought a $25 vacuum gauge, adjusted the idle screws and timing until i got max vacuum with minimum turns out and it passed easily.
i hate messing with emissions in arizona but at least it's not california! |
