So the previous owner of my truck appears to have butchered the painless performance wiring harness. I have a motor and switch but the only wire i have is the constant hot one. I need to know what to hook to where so I can get my wipers going. Can anyone help?
Zachary M. Sefcovic ![]() —— 1970 C10 454 BBC +0.030 over, TH400 - lowered |
#2 | |
The Older Generation
Re: Wiring up a wiper motor with no harness
Positive is the Yellow wire and it comes from the fuse block to the washer pump then on to the wiper connector. Here is a picture of the wire connections on the wiper & pump. The Brown connector is the washer pump and the 2 Black connectors are for the wiper. The Light Blue, Dark Blue, and Black wires are ground wires and go to the wiper switch in the dash. The wiper/washer switch has to be mounted in the dash before the wiper/washer will work because that is where the system gets its ground...... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-31-2020 at 11:55 PM. |
Thanks! That should be enough for me to be able to wire it up
Tags |
1970 c10, electronics, sbc 350, wipers, wiring help |
