Alternator/wiring issues in LS swap 74
Hi all,
I have installed a 2003 ls1 from a local Australian commodore. This should be similar to the first year gto and potentially the early Camaro. It has a two pin alternator. I am having issues with the alternator or the wiring for it. I have wired the top white wire to the new constant power bus bar IÂ’ve installed ( IÂ’ve removed the old two post unit on the fire wall). The bottom brown wore I have hooked up to the existing brown alternator wire that goes through the firewall to the ignition switch. I have cut and wired in a 3v t10 globe into this wire between the firewall and ignition switch for an indicator light and added resistance as this is what I have read the alternator needs to avoid burning out. Everything seems to be running great, engine and the alternator is charging the system, but the alternator light will not illuminate. ThatÂ’s my first issue. Second issue: while trying everything to work out wtf is going on I noticed with the battery connected the alternator got warm. After talking to a couple of mates I decided to replace the alternator as the seems to be a lot of people saying that indicates the diodes are stuffed. After replacing the alternator with a new one, the new alternator is also getting warm(I donÂ’t think as warm however) and the light is still not illuminating. Can someone help me work out wtf is going on? Cheers! |
Re: Alternator/wiring issues in LS swap 74
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
Thanks!
I have read that before and that’s what I’ve followed for the install but I can’t get that light - wired in as noted- to illuminate! No idea what I’m doing wrong. Starting to wonder if the alternator is wired up differently to the older style? |
Moderator
![]() Join Date: Oct 2008
Around 2002-2005 or so GM started to phase in PCM controlled charging. I'm not sure when the Holden division started to do that.
You could have an AD series alternator that's expecting a charge control signal from the PCM. If you have it wired up as a self exciting self regulating alternator like the old SI and CS series that may be part of your problem.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#5 | |
Any ideas what’s going on? |
