Just here to tinker
![]() Join Date: Jun 2008
Help decoding firewall markings
Hi All,
I just recently picked up a '67 GMC C15 and I noticed there are what appear to be factory assembly line markings all over the firewall. Any one know what any of these might mean? I'm specifically interested if any of these are my paint code as my SPID label is long gone. Any help is appreciated. Thanks! CORT
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Just here to tinker
Re: Help decoding firewall markings
The CE1590D is the first part of my VIN so I know what that one is.... Could the 550 be my paint code?
550 is paint code, not sure on j70, is the truck a power glide truck- pg on hood. Typically the paint code is around trans tunnel over to brake master. My 67 also had it on the driver side hood bottom. Vin and wheel base info on passenger side. May be a mark or two under heater box as well, 67 I helped a friend with actually had USA under heater box. One of my 71’s has a/c under box and 118 in letters about 14” tall under driver side bucket. My 72 4x4 was signed by John on gas tank. Where was your truck built? Seems like trucks built at Baltimore plant were written all over.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Just here to tinker
Thanks for the help! My truck was built in Pontiac. The truck has a THM400 now and I am not 100% it is factory, but the shift indicator has three speeds and I am sure it is original so I don't think it was a power glide.
Anyone know what color 550 would be ?
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
The 550 is an assembly line number not a paint code
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
![]() Join Date: Oct 2009
J70 told the worker to install a brake booster (and your SPID would have had a J70 RPO).
2T is the trim # (Z62 in this case) (and your SPID would have had a Z62 RPO) CE1590D is your model #, not a partial VIN: 2WD V8 1/2 ton lwb fleetside. (and that would have been on the SPID also) A 550 paint code means ivory top over light yellow body in 67, but I agree with 67 twins that that is likely the line sequence number. But, it's also possible that 560 (not a valid paint code btw) is the sequence number and 550 is a paint code (I don't recall seeing the paint code on the firewall normally). Just not sure... So, what color IS your truck - i.e. when you look at the telltale signs of original paint (if it's been repainted)? |
But, it's also possible that 560 (not a valid paint code btw) is the sequence number and 550 is a paint code (I don't recall seeing the paint code on the firewall normally). Just not sure... So, what color IS your truck - i.e. when you look at the telltale signs of original paint (if it's been repainted)?[/QUOTE] Think about it like this. What use is a paint code on a truck that is already painted? So why would the paint code ever be on the firewall?
Most 67 gmcs did not have spid by the way. Not sure why.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
#9 | ||
Just here to tinker
Just here to tinker
I'll take a better picture of the interior roof as it is still original. It doesn't seem to be either the saddle fawn or silver fawn, but it seems green-ish. Did the 67's ever have the exterior color painted on the inside?
Just here to tinker
Well I used some rubbing compound on a small part of the firewall by the heater box and I swear that looks yellow. Also, there is some flaking under the cowl vent that looks quite yellow as well. Maybe the 550 is right?
My 68’ GMC has 520 written across the trans tunnel, just behind the distributor. Happens to be the proper paint code. So I assume that’s it’s not a coincidence. I’ll look for some pics.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
