04-10-2020, 09:21 PM | #1 |
Just picked up an 85
Just picked up the newest squarebody I’ve had to date. 1985 Silverado 3/4 ton camper special with a factory 454 and 4 speed. It was only about 15 miles from me and the guy said he parked it because he thought the clutch was going out. Anyway got it home today, threw some fuel on the passenger side tank and started cranking and she fired up. Runs smooth and the clutch actually works fine. But if anyone can help me with this I’d appreciate it, the front brakes were really tight at first and I cracked each line and they released. So I drove it and after using the brakes a couple times they got really tight again but release if I crack the line. So would that be an issue in the proportioning valve? Or in the calipers? If anyone has a clue let me know, but I think the brakes got tight on him and maybe got hot and it wouldn’t move so he assumed the clutch was out. Anyway here it is, been repainted white at one point from what I can tell.
04-10-2020, 09:23 PM | #2 |
Re: Just picked up an 85
And the spid. Has all four original whee covers but I think I’ll go with the dog dish like in one of the pictures
04-11-2020, 04:24 AM | #3 |
Take the calipers off and lube the slides. Also may be a good time to go ahead and put new pads on....just to make sure that the pistons aren't coming too far out of their bores. It's possible that the combination valve has too much residual back pressure from being dirty/ stuck. Maybe flush out the system with all fresh fluid before tossing parts at it. My $0.02
04-11-2020, 07:57 AM | #4 |
It could be your brake hoses. They are known to deteriorate inside and not let the fluid return to the reservoir. I'd try that first.
04-11-2020, 09:18 AM | #5 |
X2, brake hoses.
04-11-2020, 07:56 AM | #6 |
I would replace the rubber lines while you were in there just to make sure they aren't collapsing and holding pressure at the caliper.
04-11-2020, 11:06 AM | #7 |
Nice truck! X3 on above.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-12-2020, 01:53 PM | #8 |
x4. Replace the brake hoses. Lube the caliper pins while doing the brake service.
04-12-2020, 05:03 PM | #9 | |
So while you're in there, might want to think about re-packing.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
04-12-2020, 06:51 PM | #10 |
Truth. I didn't think to mention that but I've never owned a vehile w/sealed bearings.
04-12-2020, 09:07 PM | #11 | |
Back in my service station days, re-packing wheel bearings was a big part of our business. Also an essential part of replacing front drum brakes.
04-12-2020, 05:01 PM | #12 |
I’ll try out the rubber brakes lines and spraying down the calipers. If not they’re not too expensive to replace
05-06-2020, 09:01 PM | #13 |
I replaced the old rubber brake lines and they fronts no longer stay locked up but I bled them once and the pedal feels soft but it’s stopping it. Tried bleeding them again with no change but when I hit the brake pedal and push it down almost to the bottom the brake light comes in. Still a little spongey for my liking so would the next step be the proportioning valve?
05-06-2020, 09:56 PM | #14 |
sounds like the proportioning valve got off center. need to bleed the front and rear again and get all the air out, and hope it will recenter by itself.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
