04-10-2020, 09:39 PM | #1 |
72 big block swap pulleys
i'm having trouble finding pulleys to work with my short water pump big block i order a three piece set and the power steering looks like it needs a three groove pulley to work and it came with two i've got reproduction power steering pump mount from ccp if i use a set from a two wheel drive big block are they double groove crank pulley or triple i'd prefer double so their would be no clearance issues if two wheel drive pulleys would work where would i find them
04-11-2020, 09:26 PM | #2 |
Re: 72 big block swap pulleys
I put together my pulley set using 1967 375hp 396 pulleys from a Chevelle. The Chevelle uses the same power steering setup as the truck and the high perf 375hp pulleys are deep groove.
You can also use the 325hp 396 pulleys that have the same ratio as the truck pulleys. Brace yourself though, they are expensive. Most cost effective may be to find a used set of pulleys here on the board.
04-11-2020, 11:06 PM | #3 |
how expensive
04-12-2020, 09:10 AM | #4 |
Two groove crank pulley is $120. Add on pulley to make 3 groove is $50. $110 for water pump pulley. $50 for the single groove power steering pulley. $50 for the oversize alternator pulley.
If you want the original style two groove cast iron crank pulley it's a $200 part. The cast iron hi-po steering pulley, another $50. But you can piece together a low perf pulley set for a couple of hundred bucks. Edit: shopping around finds a big disparity in prices. Here is a two groove waterpump pulley for just $85 https://www.camarocentral.com/1967_1...p/enc-1007.htm
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 04-12-2020 at 09:15 AM. |
