Old 04-12-2020, 12:02 AM   #1
Spun Bearing
Spun Bearing's Avatar
'73-'87 Control Arms are Tight
I bought pre-assembled '73 - '87 control arms for my '64 . They are very tight, I can't get them to move with all of my body weight. Will this be okay once I have this back on the ground? Seems wayyyyy to stiff to me. If I need to correct this, how?
Spun Bearing is offline   Reply With Quote
Old 04-12-2020, 10:43 AM   #2
SkinnyG
SkinnyG's Avatar
Re: '73-'87 Control Arms are Tight
Probably fine.
I imagine you weight far less than the 1300lbs that are going to sit on that control arm.
The bushings are rubber, only about 1/4" thick or so, and often glued to the arm and sleeve inside. That doesn't allow for much flex. I say run it!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 04-12-2020, 04:09 PM   #3
Wrenchbender Ret
Don't tighten the end nuts up until you have the arm in the center of the travel.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-12-2020, 11:54 PM   #4
'65 chevy lover
Run it, it's fine
'65 chevy lover is offline   Reply With Quote
Old 04-13-2020, 09:31 AM   #5
SCOTI
SCOTI's Avatar
George
x2.
The A-arm shaft hardware @ the bushings is not supposed to be torqued to spec until there is full weight on the suspension. It still binds.... It is just closer to where everything should be.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
