04-13-2020, 02:30 PM | #1 |
Leaky radiator
I have a small pinhole in my radiator that seems only leaks when ambient temp is over 80. Anyone have any suggestions for an additive I can use in my rad to stop leak? Can I take it to a rad shop for them to fix?
1970 402 w/AC, AT 400TH
1970 C-10 CST, LWB, 402/400, A/C |
04-13-2020, 02:39 PM | #2 |
Re: Leaky radiator
This is what GM recommends. It's effective and doesn't gum things up and is widely available. This came up with a quick search. If it doesn't work, take the radiator in for a simple repair.
https://www.walmart.com/ip/GM-Coolin...yABEgLDTfD_BwE
Jim |
04-13-2020, 02:45 PM | #3 |
Re: Leaky radiator
Thanks Jim.
04-13-2020, 03:29 PM | #4 |
Re: Leaky radiator
Bars Leak is good also. It is available at all parts stores.
04-13-2020, 04:05 PM | #5 |
Re: Leaky radiator
Results from Mythbusters episode where they tested the 'ol egg in radiator to stop leak... When there is a leak in a car radiator, cracking an egg into the radiator will plug the hole. PLAUSIBLE The engine was started after the contents of an egg were poured in, and the leak stopped. Just sayin'... -klb EDIT: https://mythresults.com/episode15
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
04-14-2020, 12:39 PM | #6 |
Re: Leaky radiator
Mark the hole, pull the radiator and solder it up.
Everyone wants a pill to fix problems, myself included. Go through the pain, and get it over with. Or..... |
04-14-2020, 05:28 PM | #7 | |
Re: Leaky radiator
Get a little flux in there first
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
04-15-2020, 09:13 AM | #8 |
Re: Leaky radiator
Good ideas....thanks guys!
04-17-2020, 07:10 PM | #9 | |
Re: Leaky radiator
And based on my experience, I would NOT use Bars Leak unless an absolute emergency just to get you back to civilization.
'72 Chevrolet C10- Deluxe/5.7/Short Fleetside '02 Chevrolet Tahoe- LT/5.3/4x4 '13 Ford F150- XLT/5.0/SuperCrew/4X4 '14 Subaru Impreza- Limited/2.0/Sedan/AWD |
04-17-2020, 07:17 PM | #10 | |
Just here to tinker
Re: Leaky radiator
But definitely pull the radiator and solder the correct way as mentioned above. Only way to go.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
