Old 04-13-2020, 05:58 PM   #1
FLYNAVY30
Need some help with coil spring replacements
It has become apparent that part of my covered wagon ride quality is due to sagging coil springs. The rears in particular have multiple coils touching with the weight of the truck on the ground.
My Suburban is a 1972 3/4 ton C20 that came with the 402 cu. in. big block. Looking at the specified replacement springs from Moog:
Front: 6104 constant rate
Rear: 6101 constant rate
6103 constant rate heavy duty
CC603 variable rate
CC615 variable rate heavy duty
So with only one option for the front, that decision is quite easy. My question is, what are the proper springs for the rear to match the front? I'm assuming the HD springs would be used in a truck that saw frequent heavy loads or towing? I'm also not sure variable vs. constant rate.
Any input would be greatly appreciated!
Greg
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
FLYNAVY30 is offline   Reply With Quote
Old 04-14-2020, 08:43 PM   #2
aerotest
Re: Need some help with coil spring replacements
I went with the gmc Paul’s front bb springs and rear 4” drop. The fronts are identical to stock and the rears are much softer variable rate. Rears are nice for a softer ride but towing capacity is definitely dimensioned.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 04-14-2020, 08:55 PM   #3
HO455
HO455's Avatar
Here's some links that may help with the decision.
http://67-72chevytrucks.com/vboard/s...d.php?t=336257
http://67-72chevytrucks.com/vboard/s...d.php?t=776387
RIP Bob Parks.
Old 04-14-2020, 09:29 PM   #4
FLYNAVY30
Thanks, that was a big help. I did some additional reading about constant vs variable rate. I think for now Ill stick with the regular, constant rate springs for my application. This is obviously a short term solution anyway while I decide how best to attack the chassis swap/ 4wd conversion.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
