Old 04-14-2020, 04:43 PM   #1
chrismoore701
chrismoore701's Avatar
The infamous belt squeak
So I know this has been debated a 1,000 times for the best way to fix this problem. I have a 350 with an alternator, water pump, crank pulley. And a power steering pump to crank pulley. Well my belts squeaked. Very soon after a fresh build with painted pulleys. I sanded the paint off the pulleys, still squeaked, I sanded the belts, no luck. Looking at the belts really close, the alternator looked a little narrow. Bought a new thicker one and now they seem worse than before. I also tightened the power steering pump, not banjo tight, but tighter.
Options? belt Dressing? Saw some on line, maybe at autozone?
What do you guys think? it is driving me crazy.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-14-2020, 05:40 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: The infamous belt squeak
Does the belt have any rust on them still. Or does the belt to lose still. Or is it sitting to low in the pulley grove.
I paint black water pump and power steering grove Gray to keep eye on how much wear the belt getting as I see more gray paint to more the belt wearing out. I do not get squeaking belt normly unless the pulley got rust rubbing on the belt or to loses or belt lined up some times belt have cracking or splits in it or gouges in it.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-14-2020, 08:16 PM   #3
chrismoore701
New belt and sand blasted the pulleys so all new and clean
Chris
Old 04-15-2020, 08:27 AM   #4
Pontiac1976
How old is your ALT pulley. Is the new belt cogged belt on the in side or the out side or does your Brand. Is your Alt pulley letting the belt sit to low in the pulley as the cogged belts start to bottom out move more then the old v-style belt slip move in the pulley need to be a little tighter then them, need to be all most flush with the top of the pulley. They have to have little bit of room to sqeeze down when RPM's get higher. With out bottoming out in the pulley grove or they start to bonce more be lose could make noise or pop off or brake the belt in the shorter term. Pulleys can't wore out to much year's miles as much as the belts some of the newer belts to thin as some are to thick the right combo of belt pulley can work better. Remember the name V-belt v-belt pulley
Wear out in a V shape so the pulley wear out wider & deeper and the belts wear makes them wear thin. So think of the way they work together belt gets tighter higher RPM make them grip more but only on two edges about @ about 3.5mm to 6mm after that if the bottom touching slow the belt down heats the belt up more making the belt jump or start to vibration or try to stop the pulley like brake. You want the belt to around 3.5 mm of the belt best performance run. As RPM start to rise the belt should have room to be pulled down but not bottom out. But not sit too high or higher RPM when belt start to vibration has have room to be draw n down the belt take some of the vibration out as they tightens if they don't bottom out. So it important to check belts and pulley wear. And how fit together properly. As I said I paint pulley groves to see wear help slow the wear to the main pulleys.
Old 04-18-2020, 11:13 PM   #5
TrailerTrash
TrailerTrash's Avatar
Do the pulley sizes match? Let's see some pics
EDIT: hmm I think I read your post wrong. Let's see some pics anyway I've had alot of trouble with this myself before I solved the issue
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 04-19-2020, 07:45 AM   #6
1967KaiserM715
1967KaiserM715's Avatar
could be bearing squeak from alternator, waterpump. run it without PS belt, see how it sounds. try running just alternator, try to determine where the squeak is coming from. if it is the belt, try a different brand?
1967KaiserM715 is offline   Reply With Quote
Old 04-19-2020, 10:39 AM   #7
Nickelcharlie
Mine was horrible sounding! Last weekend I replaced them with Gates belts and it is like a new truck all nice and quite. I also saw a video where they sprayed the belts with 303 and it stoped the squealing. Might be worth a try before replacing the belts. Be safe around the belts if you do spray them with 303 or anything else if the engine is running!
Nickelcharlie is offline   Reply With Quote
Old 04-19-2020, 09:19 PM   #8
buffydores
buffydores's Avatar
Apply dielectric grease to the belt. Magic.
Old 04-20-2020, 09:10 AM   #9
cadillac_al
Really? I would think that would make it slippery. I always said I was going to try sweet and sour sauce from the Chinese restaurant. that stuff is super sticky lol.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-20-2020, 09:15 AM   #10
buffydores
buffydores's Avatar
Again. Magic. Been using it for years.
Old 04-20-2020, 10:22 AM   #11
Richard2112
Richard2112's Avatar
My brothers car had this problem. We checked the pulleys for alignment and put an underdrive pulley (Larger diameter) on his alternator. Depending upon the angles the belt both enters and exits the pulley, more or less surface contact can be had.
Richard2112 is offline   Reply With Quote
Old 04-20-2020, 07:34 PM   #12
cadillac_al
I can't wait to try that magic. Thanks.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
