Old 04-20-2020, 11:30 AM   #1
MARKDTN
5-speed manual for stock 250
I have a friend who's father in law has a 65 C10 that his father bought new. He drives it every day. Engine has been built 2-3 times and the speedo hasn't worked since the 80s. It has a 250 (from a '68 Nova) and 3 on the tree. The transmission is about to die and the column shift is completely worn out.
What is the easiest 5 speed to put on the back of a stock 250? He does not care about the speedometer. Can you use an S10 4.3 5-speed?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-20-2020, 11:37 AM   #2
Wrenchbender Ret
Re: 5-speed manual for stock 250
Yes. The S-10 5 speed is ideal for that application. Search this website & others. There is gobs of information on this swap.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-20-2020, 04:27 PM   #3
jocko
jocko's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=482069
Old 04-20-2020, 09:48 PM   #4
maverickmk
maverickmk's Avatar
Holy crap! Now that's how you do a write-up. Nice work.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 04-21-2020, 03:24 PM   #5
typerr
Wow!
When I swapped my Camaro WC T-5 into my C-10 I could swear I came across a company or two that made the adapter plate for mating an S-10 T-5 to our stock bellhousing.
BTW, replacing my floor shifted 3-speed with the T-5 was probably the best modification I've done to my truck so far from the standpoint of drivability and usability. No more listening to the engine roar on the freeway when I'm only doing 65 mph. No more searching for a gear everytime I downshift. She's a cruiser now.
typerr is offline   Reply With Quote
Old 04-21-2020, 08:50 PM   #6
jocko
jocko's Avatar
Originally Posted by typerr View Post
Wow!
At the time, there were a few, but all were out of stock and no projected restock date. This one cost me about $10 if I recall.
Old 04-21-2020, 09:33 PM   #7
Richard2112
Richard2112's Avatar
Excellent write-up.
Richard2112 is offline   Reply With Quote
Old 04-21-2020, 09:23 AM   #8
Bigdav160
Bigdav160's Avatar
I think the NV3500 is going to be easier to find than a T5,
I think it would work fine behind a small 6
If you do a search you are likely going to find lots of post of people blowing them up behind the torque of V8's
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-21-2020, 10:27 AM   #9
Wrenchbender Ret
I've built 3 of them behind 350 v-8s & never have hurt one. Of coarse i'm an old man & drive normally.
George
Old 04-21-2020, 11:56 AM   #10
MARKDTN
Thanks! That is what I was looking for.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 04-21-2020, 08:52 PM   #11
jocko
jocko's Avatar
It really doesn't matter what you put it behind, it matters how you plan to drive it. If you're doing burnouts from stoplight to stoplight, T5 not recommended behind anything. If you're going to drive it without harsh shocks to the system, it's perfectly fine behind any small block.
Old 04-22-2020, 08:17 AM   #12
MARKDTN
This is an old man in an bone stock 6-cyl truck. Nobody else drives it. I think he goes 25 or so miles a day to work and back. It will not be abused. I think this is the original 3-speed with nobody-knows-for-sure-because-speedo-been-broken-30+-years but say 500K miles?
I appreciate all the advice. I am just the info gatherer for my friend. They may find another 3-speed and go some more. I was just trying to see how much of a project this might be as good 3-speeds are getting harder to find and the pick-a-parts seem to have these S-10s.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 04-22-2020, 03:11 PM   #13
typerr
Too bad you are so far away. I have a perfectly good 3-speed sitting in my backyard free to whomever wants to come and get it. I'll even throw in the floor shifter.
Old 04-21-2020, 10:54 PM   #14
burnin oil
the nv3500 will hold up fine behind a stock v8. I have personally owned 3 stock 350 trucks that had one version or another without problems. 2 TBI and one vortec truck. An inline motor should never hurt one.
burnin oil is offline   Reply With Quote
