04-23-2020, 04:00 PM | #1 |
Was the hub assembly painted from the factory
I and cleaning up my front end before I replace everything and I sandblasted the hub assembly and it looked like they were painted from the factory. Can I use I temp paint on these or should I just leave them like this.
04-23-2020, 04:16 PM | #2 |
Re: Was the hub assembly painted from the factory
Assuming you are talking about a lockout hub or front axle hub. I just used standard semi gloss black rust oleum on mine. I would not paint the wheel mounting surface however.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
04-23-2020, 04:36 PM | #3 |
So dont paint the mounting surfaces on this.
04-23-2020, 04:46 PM | #4 |
Yes, thats correct.
04-23-2020, 05:02 PM | #5 |
Than you. I appreciate your input.
04-24-2020, 09:29 AM | #6 |
are those raised edges in the pics ?? I would run those flange surfaces with a hand stone just to make sure every thing is flat
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
