1964 C10 parking brake question
I have a '64 short bed C10 with 11 inch drum brakes in the rear, and I am trying to install parking brakes. The original parking brake system was removed by someone long ago, including the arms inside the drum that the spring attaches to in order to put tension on the shoes to engage the brakes. I've not been able to find any. Does anyone know where I may be able to find the left and right parking brake lever arms that attach onto the drums to engage the parking brake? Is there a wide range of year models that may fit the '64? Thanks for any help.
One foot in front of the other
![]() Join Date: Aug 2008
Re: 1964 C10 parking brake question
I thought Raybestos sold a repair kit.
Moderator
![]() Join Date: Dec 2012
You're in the same boat I was. The only thing left on my truck was the cable in the cab, and that turned out to be seized. Replaced everything. Used cab cable and handle. New cables underneath.
The pieces you need aren't repro'd to my knowledge. I got a used pair from Bill's Truck Shop up here. From a 67-73, though. He showed me where a little grinding was needed to make them work on my 65. Worked like a charm, I have perfectly functioning parking brake. |
What parts are you missing?
That picture doesn't show the park brake lever. it attaches to the shoe. They are actually obsolete for 64-66 trucks but newer ones work as they are almost the same.
I am going out on a limb... I believe I found a 1/2 ton obs and grabbed the guts. Its pretty much the same levers.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Moderator
Bigmoe has the correct pic, that was missing on my truck. Good find on that realdealsteel kit!
Thanks for all the info! And fantastic find on the realdealsteel site!
![]() Join Date: May 2022
Yikes! $74.00 for two brake levers! Dang!
Give Jaime at Aspen Auto in Fountain Hills AZ a call. He has a 60-66 wrecking yard, I bet he has a set.
Revitalizing a 6T C10
![]() Join Date: Aug 2017
I had this bookmarked, the year spread shown is different, not sure if parts will fit or not ...
https://www.classicparts.com/1951-62...ctinfo/71-718/
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
