Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-28-2020, 09:37 AM   #1
Robznob11
Robznob11's Avatar
Custom led cargo/3 brake combo and dome lights, bright!
I am now offering custom super bright led 3rd brake/ cargo combo panels for square bodies! $60 shipped in usa. Square body stupid bright dome lights are $50 shipped in USA. Pm me or find me on Instagram @disciple2.rc (DM)
I can do most custom request as well just ask. Pictures are close up and do not do justice. Trust me all my led panels are bright!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-28-2020, 10:57 AM   #2
1774btcrew
1774btcrew's Avatar
Re: Custom led cargo/3 brake combo and dome lights, bright!
what is involved on installing these? Do they go directly into the socket?
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 04-28-2020, 11:43 AM   #3
Robznob11
Robznob11's Avatar
They do not plug directly into the socke because the factory never offered a 3rd brake. You need to drill out one rivet and remove the bulb guard and socket. Then you hook the ground wire to chassis ground (housing) white wire to switched power and red wire will need to be extended through cab and hooked to the brake switch at the pedal.
LED TAILS
Old 04-28-2020, 11:45 AM   #4
Robznob11
Robznob11's Avatar
You will need to drill out one rivet, remove bulb retainet and socket. Then ground the led to the housing. The whit wire will hook to switched power. And the red wire will need extended through the cab to the brake pedL switch. It will fit inside the factory lense.
LED TAILS
