Old 04-29-2020, 02:51 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
67 GMC headlight issue
I posted this in the Electrical section yesterday, but did not get a single response. So I deleted that one and posted here.
Yesterday I removed my brand new headlight switch (with great difficulty getting the pull switch loose), unplugged it, and moved the purple parking light wire into the blank spot on the female plug. This was supposed to fix it so that the headlights and the parking lights are on simultaneously. Well, the parking lights are on, but NO HEADLIGHTS now!! My dash lights and dome lights also work. I must have damaged the switch removing the pull part out. Any thoughts?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 04-29-2020, 05:14 PM   #2
GMCPaul
Re: 67 GMC headlight issue
There were 2 different headlight switches used on 1967-72 trucks. 1967-68 8-Terminal headlight switch or 1969-72 7-terminal headlight switch.
Note- 1967-68 the front park lights go off when headlights turn on using original style switch, if you want the front park lights to stay on with headlights choose the 7 terminal headlight switch as they are interchangeable.
So by swapping headlight switches from 67-68 version to 69-72 version you can achieve what you are wanting to do, it can also be achieved by moving a wire harness but I believe you may have moved wrong wire to wrong location. I'll ask dad if he has time to review the wiring diagrams of both to see what may be done to wiring to get the results your looking for and I'll post up if he finds the time to compare them.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 04-29-2020, 05:40 PM   #3
GMCPaul
Dad would like to know if you are using a 67-68 headlight switch or a 69-72?
Paul Jr @ GMCPauls
Old 04-29-2020, 07:57 PM   #4
HIGHWAY BY THE SEA
Paul Jr @ GMCPauls
I ordered what is supposedly a 67 - 68 one (twice) at the parts store. I did not know that there was a difference 68 and up at the time. I just gave them the years 67 and 68 because both of my trucks are those years.
The new one I got today worked when I installed it until I moved the purple wire again, and it stopped working too.
I thought that the first switch broke during removal because it fought me every step of the way trying to remove it from the dash.
It appears that I have learned something about headlight switches today.
Old 04-29-2020, 08:50 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
So you are saying if you move the purple wire back to it's original position the switches will not work as they did before you moved the purple wire?
LockDoc
Leon
Old 04-29-2020, 10:52 PM   #6
HIGHWAY BY THE SEA
LockDoc
Yes. Almost as if the switch shorted out or something.
