Old 05-05-2020, 04:00 AM   #1
silverado_men
Monroe Magnum 60 4“ Lift questions
Hi I‘m planing to install Monroe Magnum 60“ shocks on my 84 6.2l Diesel K20 with dual shocks in front and a 4“ lift. I found an old advertising of these shocks on a Squarebody. Can anybody help me which ones I need with a part number and maybe where to buy?
silverado_men is offline   Reply With Quote
Old 05-08-2020, 12:17 PM   #2
Matt Man
Matt Man's Avatar
Re: Monroe Magnum 60 4“ Lift questions
If you go to RockAuto.com they have shocks for the quadshock setup. The shipping will be expensive as you are in Germany.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-08-2020, 03:17 PM   #3
sweetk30
sweetk30's Avatar
unless you want the look of quad shock skip them as shock tech has gone leaps and bounds since then and single shock is way better ride than quad shock .
and cheaters trick from years ago was ford 99-03 ish ford super duty 3/4 ton or 1ton shocks with a little tweeking to bolt size and watch the lengths to what you need off the specs listed and they swap in easy .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-18-2020, 01:53 AM   #4
Ryan Hubbard
I used the Bilstein B8 5100 (24-187077 front, 24-187084 Rear) for my Suburban with a 4" lift.
Ryan Hubbard is offline   Reply With Quote
Old 05-18-2020, 08:04 AM   #5
sweetk30
sweetk30's Avatar
yep forgot this . the bilstein shocks are the best option for off the shelf ride quality these days .
and these guys have them built to there specs from all the years of working on the square body 73-87-91 trucks / blazers / suburbans / crew cabs . www.offroaddesign.com
Old 05-18-2020, 12:27 PM   #6
Vicente Aceves
Silverado_men, I’m not trying to hijack your thread but I have a question for you guys here. It’s somewhat related to your post.
I have a 75 K10 swb that I recently picked up. I’ve never owned a pickup like this before. It has several aftermarket parts that are 70s/80s style which I like.
It has blocks in the rear and from what I can see, nothing but quad shocks in the front to make it different than stock, suspensionwise. No quad shocks in the rear.
This may sound dumb, but if I want to keep the same quad look with the more normal ride quality of a single shock at each corner, can I just leave the quad shock setup and run two “dummy” shocks in the front that don’t do anything. If so, maybe you can tell by looking at the shock mounts in the pictures, if there would be unequal stress on just the one normal shock.
I hope this made some sense.
Also if I want to put 33” tires on the truck how do I lift the front so it doesn’t rub? It looks like the backs would clear fine. This is how the truck sits now. The tires are currently 30x9.5x15
Thanks for any help -Vinnie
Vicente Aceves is offline   Reply With Quote
