1970 k10 frame questions
Someone plowed with my truck before I bought it so there's some tweaks in the frame. Its not out of diamond but I have a couple questions some of you may be able to answer.
First, I,d imagine where the front spring shackles mount behind the engine crossmember are supposed to be straight and not angled. Pic attached. Second, my transmission, transfer case, and k member are all bolted on. Just wondering if that's original? Third, I see the 4x4 body mount bushings are different than 2x4 just wondering if the 4x4 bushings are necessary. Thanks in advance |
All about them K’s
![]() Join Date: Jun 2014
Re: 1970 k10 frame questions
It’s hard to see the angle you speak of in the shackle mounts, they look ok to me. As for the transfer case and engine mount crossmembers, Yes they were bolted in from the factory. And yes the Body mount bushings are 4x4 specific and necessary. All that aside it looks like you’ve got a solid frame for being in ny!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
