05-10-2020, 07:36 PM | #1 |
TH350 Bushings Questions
So I have a TH350 that I'm rebuilding. 1970 C20.
Learning as I go and doing okay so far. I see wear on my Thrust Washers as they are steel and copper. (or bronze?) Ordered a new set of Thrust Washers and expect them to be Delrin/plastic. Ordered new Torrington Bearings that I may or may not need. (old ones look good) Also, Forward Sprag was toasted! Rear one looks great. So ordered one Sprag. Bushings? I know nothing of the bushings? Pulling them out. Pressing them in. Something I've never done. If my Thrust Washers are worn, should I expect the bushings need replaced? I know that's two different forces, rotational and load? Is there a way to measure the bushings? Diameter compared to shaft? If so, how much +/- for fluid? Can you point me to a thread that already covered this? I've been reading more than writhing here for a couple weeks and learning a LOT! Any tips, thoughts, info on bushings will be much appreciated! Cheers! Btw...3 weeks ago I couldn't find good swap rebuild. Now that I'm this deep, a guy shows up on Craigslist that I WISH i'da met 3 weeks ago?!? |
05-11-2020, 07:06 AM | #2 |
Re: TH350 Bushings Questions
Find a mandrel and remove old bushings with a lit tap then using old bushing tap the new ones in if you do not have a seal driver
Last time i did mine i had to buff out inner diameter of the bushings they were a little snug for the yoke abd converter snout
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-11-2020, 07:08 AM | #3 |
th 350 holds 10 qts normally 4 in the pan 6 in converter
05-11-2020, 09:00 PM | #4 |
Take the parts that need new bushing pressed in to a transmission shop. They will have the correct drivers to install them the right way. Also check your drive shaft yoke it maybe worn a little.
