Old 05-10-2020, 08:08 PM   #1
malc1080
Carburetor 454 won’t turn on
Hi I have a 1980 c10 454 with a Holley 4160 carb. The truck was running good for months but now it won’t start. I have to pump the gas pedal repeatedly while cranking so it can start up. It then dies. When it was running, I would floor it and it will hesitate to run and will do popping noise in the exhaust. It started when I switched to the 2nd gas tank that hasn’t been used in a long time. I have used up the tank and went through a couple fresh gas and was running for a while with that tank. I have used carb cleaner down the barrel while working the throttle and have replaced the fuel filter on the carb line. My question is how can I get it running ? Do I have to change the mechanical fuel pump, change the fuel lines, clean the gas tank , and do an carburetor rebuilt with the renew kit? Any help and advise will be much appreciated! Thank you and happy Mother’s Day!
malc1080 is offline   Reply With Quote
Old 05-10-2020, 09:36 PM   #2
farmall
farmall's Avatar
Re: Carburetor 454 won’t turn on
You have a fuel pressure gauge. What does it show when cranking? Is there fuel in the filter when cranking? Symptoms are lean. Vacuum leak?
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 05-10-2020, 10:17 PM   #3
malc1080
That fuel pressure doesn’t work unfortunately. That’s how I got the truck . Yea there is fuel in the glass filter and I sprayed carb cleaner around the intake for leaks and there wasn’t any . So I’m not getting enough fuel right? Guess I will have to redo everything plus new spark plugs and cable?
Old 05-10-2020, 10:30 PM   #4
Dead Parrot
Check the suction lines from the tanks to the valve and the valve to the frame. Those are out of sight and often forgotten about.
Try filling the carb bowls via the two vents and see if it starts normally. It won't run very long on just the bowls but it should tell you if your issue is fuel or other.
Double check the timing just in case the hold down bolt picked the time you swapped to the other tank to loosen and let the distributor change timing.
Possible enough rust and crud got through that filter and is now in the carb. If your testing keeps pointing at fuel, I would start with a carb refresh.
Might put a filter between the frame and fuel pump to keep tank crud from reaching the pump.
Dead Parrot is offline   Reply With Quote
Old 05-10-2020, 10:56 PM   #5
malc1080
Thank you both for the replies! How do I check the suction lines ? And is that the lines attached to the tank?
Ok I’ll add fuel to the primary two throat vents? Where the jet squirt fuel right?
I’ll definitely check the timing once I can get my hands on a timing light !
I think rust was what caused all this. I’ll definitely put a second fuel filter between the frame and fuel pump
Old 05-10-2020, 10:59 PM   #6
malc1080
The only problem is checking the timing is going to be tough if I can’t get the truck to stay running 😔
Old 05-11-2020, 08:42 AM   #7
Dead Parrot
Suction lines are the ones from tanks to switch valve and from valve to frame and from frame to fuel pump. A hole in one of those lets air it and can limit or prevent fuel flow.
You should be able to add fuel into those two pipes with angled ends on the carb top. They should be the fuel bowl vents.
True on the timing and running engine! For a quick check, see if the distributor is still tight and won't move. If it is, probably safe to assume it hasn't moved until you can confirm with a timing check. My suggestion on the timing check is because poor timing can mimic some fuel issues and it is a lot easier to make sure the timing is good then dropping fuel tanks.
Based on the rust in that filter plus the problem starting when you started using the 2nd tank, I think your rust theory is probably correct.
Please make sure that clear filter is an automotive filter and not one of those outboard motor filters. The outboard filters are designed for the suction side only and are not pressure rated.
Old 05-11-2020, 02:45 PM   #8
malc1080
Thank you for the replies!
Ok once I get home I’ll go underneath and take some pictures so i can get some help on identifying the suction lines. I’ll check for anything usually.
I’ll try adding fuel through the pipes and see what happens.
I’ll also check for a loose distributor. I hope it’s not that since it was working perfectly before.
So if it’s the rust, I’ll go ahead and start on repairing all the things I mentioned, fuel lines, carburetor rebuilt, fuel pump , spark plus and wires . I just don’t know which fuel pump to get. I see they vary from GPH . From 40 bucks on LMC to over 100 On summit racing.
My 454 is cammed and that’s all I know about it.
Damn I got it at the auto store . I’ll go back and retrieve the package from the trash to make sure .
Old 05-11-2020, 10:20 AM   #9
blazer2007
small crack in fuel line,?
blazer2007 is offline   Reply With Quote
Old 05-11-2020, 02:45 PM   #10
malc1080
I’ll check for any cracks!
Old 05-11-2020, 09:08 PM   #11
blazer2007
When I had a small crack in the fuel line it would start better on a full tank of gas and as the tank emptied it would get harder to start. Check where the bends are. It didn,t leak that you could see drips but when I found it you could see it wet. I chased it and spent money on new fuel pump etc.
Old 05-11-2020, 10:27 PM   #12
malc1080
I’ll check! Thanks for the advice. Need to get under there. Didn’t have time today to do it. Tomorrow for sure!
Old 05-11-2020, 10:41 PM   #13
Dead Parrot
If you got the filter at an auto store, its probably OK. Just make sure it is rated for the pressure side of the system.
The ones I am thinking about look similar but are found in the marine sections of Walmart or Academy. They are meant to go between the 6 gallon boat gas tanks and the outboard where the outboard is sucking the gas out of the tank.
IMO:
1 Only use gas from the pre-trouble tank.
2 Add the filter between the frame and fuel pump. (low cost and easy)
3 Clean and refresh the carb.
Only if the above doesn't clear the problem would I worry about the fuel pump. They are normally fairly durable.
Once you get the truck running good - then worry about dropping the 2nd tank and inspecting things. Very possible the sock on the sender is toast and let years of crud into the system. Or added bits of sock to the problem. (When I replaced the leaking driver's side tank on my 75, the remains of the original sender sock was half sucked into the intake pipe. I do have a filter between the frame and fuel pump so no harm done.)
Old 05-12-2020, 12:02 AM   #14
malc1080
Thank you so much for the help. And every too!
The filter was made by a brand called mr gasket and doesn’t say the psi . Just says not for fuel injection.
Ok I’ll only use the good and I’ll add a fuel filter under! Where is between the frame? Is it just side the bed frame?
And I’ll do the carb with holleys renew kit! That’s going to be tough but I’m always looking at YouTube videos! This is my first c10 and new to everything! Ready to learn and one day help others for free.
Old 05-12-2020, 12:04 AM   #15
malc1080
Is the sender inside the gas tank?
Old 05-12-2020, 12:05 AM   #16
malc1080
And will I need 2 filter between the frame one for each tank or one before the fuel pump for both tanks?
Old 05-12-2020, 06:40 PM   #17
truckin 79
The best thing about a holley carb is checking to see of fuel is in bowls. On the passenger side you see those flat screws on bowls? Gently remove sight plugs and fuel should dribble out of it, then you know it is fine. If fuel comes pouring out then it is probably flooded. If it is flooded you can remove needle and seat from top of carb bowl and see what kind of debris might be in there. You can proably find a youtube video that shows you all this. That way you are not tearing apart things you dont have to. Also you can run to parts store and get a spark tester, looks like a spark plug that you ground on metal and you should see a spark jump across. Quick easy checks on fuel and spark.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 05-12-2020, 07:37 PM   #18
malc1080
Ok I was came back from getting the truck to run by closing the manual choke and holding the gas to keep it running. I then turned it off and removed screws as this is what I found. The first fuel bowl just dribbled out and i can see the fuel . If I rocked the truck side to side it will dribble. Now the fuel bowl behind it had no fuel at all. And I have gas linking from the diaphragm and it is wet between the gasket on the adapter plate that’s the carburetor sits on top off. It’s on the driver side. I have provided pictures and I’m pointing at it with a screw driver ! Thanks !
Old 05-12-2020, 07:37 PM   #19
malc1080
I have no idea by my pictures are being uploaded sideways
Old 05-13-2020, 09:40 PM   #20
Dead Parrot
Not very knowledgeable on Holleys. Is there a filter in those housings where the gas line enters the carb? Even a simple screen filter might be full of rust that got past that old filter. Qjets put a filter in a similar looking housing and Eddy carbs have small internal screens.
Old 05-13-2020, 09:43 PM   #21
malc1080
I think I’ll wait on my carburetor book I purchased. LMC sells those manuals so I got one used so I’ll wait for that and start taking it apart and post that here so anyone who ever has the same issue and just follow along! For the love of c10s!
