![]() Join Date: Mar 2018
Drive gear number for 3 speed saginaw?
I want to replace my driven gear on the 3 speed saginaw.....it leaks pretty good.
I see a lot of info about driven gears and was wondering if anyone knows the Drive Gear number for a 69 Saginaw 3 speed. I have 3.73 rear end gears and a 29.06 dia. tire. Trying to get a driven gear before i pull the old one out and thought maybe someone has that last piece of the formula?? Thanks for any help ![]()
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
#2 | |
The Older Generation
Re: Drive gear number for 3 speed saginaw?
https://transmissioncenter.net/produ...dometer-gears/ Here is their calculator. https://transmissioncenter.net/shop/...ar-calculator/ LockDoc
Just changing the gear might not cure the leak.
You likely need a new housing with a new outer and inner o-ring. Here’s an example. I’m not sure which one fits your trans. https://transmissioncenter.net/shop/...meter-housing/ |
Thanks for the info. I called the shop that you linked the info to and they told me to go to ebay. Found a shop in California that sold the housing with inner and outer seals with 5 different driven gears for 21 bucks free shipping. I'll get back to this post after receiving and installation for a review.
